Propane tank regulator for use in Spain
JamesR
JamesR
Barcelona
Grand California 600
Hey, I just got a new Grand Cali 600 in Spain, and I'm struggling to figure out which regulators I should use on Repsol Propane tanks to integrate with the camper's gas system. I've been to countless hardware stores with no luck. Even Chat GPT was confused! Any help appreciated.
You don't need a different regulator - thats already hard plumbed into the van, all you need is a clip on connector & then the hose from connector to your regulator.
ok, thanks for that... so the clip on connector doesn't need to adjust the pressure, just passes it through? Also, can you point me in the right direction, name of product or a link? - would really appreciate it.
OK, I have a new issue now... I got the clip-on connectors (in Spain), and they don't seem to be compatible with the hose provided by VW. There is not a clean/tight fit with the connectors. Do you know of a connector I could buy? See images attached. Any help would be really appreciated.
Can you ask the supplier of the valve if what pigtails they have? you must have the standard VW hose to show the supplier what you need at the van end?
Ive got one none VW hose left at home following the sale of. our van here's photos of both ends - looks the same as yours?
Eber123
TW8 GrandCali
TW8 GrandCali
Niborn
Niborn
Niborn
Campingrookie
JamesH_UK
