T7 Hybrid PHEV Camping Benefits
BenSherman
United Kingdom
T5 SE 130
Hi all,
I'm trying to find out if the PHEV offers any camping-specific benefits over the diesel and petrol models.I've searched extensively for the answers to these questions and have found lots of conflicting info!
Can the PHEV battery be used as the main leisure battery (or to recharge the leisure batteries)?
Can you run the air-con overnight?
Does the camping hook-up charge the PHEV battery?
I understand there's an inverter with 3-pin plug in the kitchen. Could I plug my caravan's hook-up into this to power my caravan (which we'll sometimes be towing as well)?
Any other camping benefits to the PHEV?
Hi all,
Can the PHEV battery be used as the main leisure battery (or to recharge the leisure batteries)? NO
Can you run the air-con overnight? YES for 20/30 mins at a time until computer says NO
Does the camping hook-up charge the PHEV battery? NO
I understand there's an inverter with 3-pin plug in the kitchen. Could I plug my caravan's hook-up into this to power my caravan (which we'll sometimes be towing as well. THE INVERTER RUNS OFF THE LEISURE BATTERIES AND HAS A LIMITED OUTPUT 300 watts.
Yes, once you start the vehicle, the phev battery starts charging both the engine and camping batteries. It charges them very quickly, mine went 50 > 100% on about 15 mins.
So you can charge batteries quickly and comfortably without ICE running.
Ahh... So you the PHEV battery does charge the leisure batteries? That's great - at least there is some benefit for camping. That should provide masses of leisure battery charge for off-grid.
Worth remembering that the diesel engine can also charge the leisure battery whilst stationary. Charged my leisure batteries from 20% to 100% in 25 minutes while the van was parked.
It's just a bit more antisocial if you're on a campsite! You're right though - on max charge it's very very quick to charge the batteries up - I have the beach so only a single 40ah battery and I went from 20% to 100% in about 15 mins driving from the dealer to my overnight spot with it on max
