Here's how to do it
1. Buy HDSD card, NOT a micro card with an adapter. i bought a 64GB one for 16.99 Sandisk. This needs formatting to Fat 32.
2. on your radio press and hold the menu button to see your installed software string. the last 4 numbers matter. here you see mine at 0351.
3. You now need to pick the software to download from the T6 forum MIB site. so for me it was the MST2 EU VW PQ P0369T. see pic 4. takes a while, file is about 3gb long. for this reason get at least a 16GB SD card. 4GB is too small as it needs unzipping.
4. unzip the files. takes a while.
5. you should end up with a list of files once opened looking like this. pic 6.
6.Copy all these files into the root directory of SD card. don't just drag n drop the original folder. open it and copy the files.
7. now insert into left SD card slot. press hold menu and you should now get the option to update. click start. the screen may restart a few times.
8. mine took around 20 minutes,so leave ignition on.
9. once done, restart the unit. hopefully you will now see the correct time.
link below that yo will find the software in.
The clock on my radio display shows 00:00, it will occasionally momentarily flicker to the correct time. Any ideas before I pull the dash apart?
www.t6forum.com
