Can't charge the leisure battery from the engine
Sorry to hear so many others are having the same issue. I’d be interested to hear if anyone has actually managed to get it fixed through their dealer. How was the experience and how long did it take?
I reported the issue to my dealer within the first week of ownership, so I believe I still have the option to reject the vehicle under the Consumer Rights Act. I really don’t want to send it back, I like the van and I’d like to give them the opportunity to fix it. That said, I definitely don’t want six months of going back and forth to the dealers!!
Hi Kevin as said before I will be taking the T7 to the dealer to install a new circuit breaker; we have been waitting about 2 months since there was no stock worldwide; they were against this idea many times but after talking directly to the electronic guy at dealers they ordered it as the most probable cause of failure; I will come back at the end of the week.
I haven't seen anywhere in this thread mentions of the Max Power button. That's what makes T7 charge leisure battery during driving. I always use it since it makes StartStop system go away :)
Thanks! I have also been experimenting with the Max Power button unfortunatly it doesnt seem to make any difference in my testing.
My understanding was that the leisure battery should still charge without the button pressed? I think I was told that the button just makes the charging faster by increasing the engine revs. Its very possible I missunderstood!!
Thanks for the info, sounds hopeful! Fingers crossed it resolves your issue.
Your assumption is 100% correct.
From what the dealer told me - without Max Charge it charges the second battery only when it's quite low. The manual is a bit foggy here:
I guess I need to experiment.
But if for you it doesn't improve anything, then probably there's some other problem - the charge controller/relay/or fuse might be blown.
Hi Kevin and all; the issue with the charging has been solved! several months took for the dealer to accept my proposal and 9 months with the "no charging leisure battery while driving".
I insisted on talking to the "electric technician" at dealers and after talking to him he admitted that could be the reason for the issue; the part was ordered and changed last week; the leisure battery now charges while drivng. Service attendants know nothing so please try to acces to the electric technician in charge of the issue. Here is the part (disyuntor=circuit breaker. VW Part No. 7t0959663 )
Good luck!
Good luck!
That’s great news! Thanks for sharing the details of the repair. I’ve just dropped mine into the dealer so I’ll forward the details of your successful repair to them. Might save them a bit of time!!
It definitely fully charges it without needing to use the "max charge" button - we left Liverpool with 20% left after a night in the van and it was fully charged by the time we got home to Newcastle without touching the max charge button.
Thanks for the clarification!
I'd be really interested in how quickly I should expect the leisure battery to charge, both with and without the max charge button pressed. I've seen videos suggesting 30%->100% in 15 minutes, sounds unbelievably quick!??
Also does it make a difference if you are driving the vehicle compared with the vehicle stationary with the engine turning over?
It is super quick - we had 30% in it when we picked it up from the Liverpool dealer - we put max charge on for the 20 minute drive into Liverpool and it was fully charged. We have a beach with only one additional battery
Following this thread as we are having the same issue on a t7 ocean cali diesel. Will try the circuit breaker
We also have the same issue our T7 , stop charging the leisure battery from the engine last week, I have it booked in to be looked at in 2 weeks time, not had any problems since new in August 25 , judging by all the threads on this forum relating to the battery issues I can see this being a battle, I’ll join the queue
Good luck!
Good news!!! I’ve got my van back from the dealers. They made the change suggested after I forwarded the above message from Jerrywho, fitting the new circuit breaker. I’ve not tested it fully yet, but my initial view is that it’s fixed it for me too.
The leisure battery was on 70–80% when I collected it, and when I started the engine it immediately began charging. Not only that, but the amps from the engine were much higher than I’d seen before (125A and 1770W with the Max Power button pressed). I checked the battery again after about 10 minutes and it was fully charged.
I’ve also noticed that the Max Power button now seems to work. Without it pressed, I observed the engine output dropping to around 40A and 440W.
I just need to drain the battery and attempt a full recharge to complete my testing, but I’m fairly convinced it’s now working as the behaviour is so different from what I was seeing previously.
Thanks so much to Jerrywho. I think your information has been key to getting this fixed quickly.
On a final note, I’ve seen a lot of negativity around these problems. I understand this and it is really frustrating to get an almost new van and have issues. That said, I’ve been really happy with how the dealer has handled it. They’ve dealt with the issue quickly and have listened to the information from this forum that I sent them which I believe has help achieve the fix. I’m glad I persevered with the van. It seems that when the battery system works, it works really well (assuming I don't start experiencing the battery drain issues now!!).
Really hope this thread helps others blitz this frustrating problem and allows them to start enjoying their van!
Please post back your findings after you have had more time to confirm the fix.
It's good to let others see the bug fixes getting confirmed.
Great news it is hopefully all fixed for you though.
These are the results of testing the fix (installing disyuntor=circuit breaker. VW Part No. 7t0959663).
The table above shows the highlights, all charging done with vehicle stationary with no EHU.
  • LB charges from 20% to 100% in 25 minutes using Max Power. In this time VB goes from 30% to 70%
  • Max Power button initially doubles the Amps from the engine (28A to 74A). This moves to 104A perhaps as the batteries warm (very cold day). I have withnessed upto 128A on other charging cycles.
  • After the LB is charged, amps from the engine reduces significantly slowing the vehicle battery charging. This happened around 27 minutes after starting charging.
I've no idea if this represents expected behaviour but its clearly much better than I was previously experiencing.
Its great to know that I can charge my LB from 20% to 100% in 25 minutes without moving the vehicle!
Hope this helps others solve similar problems and would be interested in anyone who is experiencing significantly better charging than this. Again, thanks to @Jerrywho for providing the details of the fix.
Hi all...I think mine is finally fixed. leisure battery has remained on 100% since I got it back on Wednesday 18th. Have the fridge on now to deplete the battery a bit and fully test. New control module was the remedy although the wait for the part was ~2months. Props to Citygate Wooburn Green for sorting it.
Great news! Glad it’s all sorted.
I’m interested that your leisure battery has remained on 100% after a week. Is that with the vehicle parked up or have you been driving it? My LB still seems to drain a little whilst parked up, perhaps lose about 20% over the course of a week. Think I’ll test this again properly.
Ours is only a couple of weeks old and also tends to lose around 20% in a week if not driven at all. I think this is considered normal but I could be wrong.
