Cordless Trickle chargers
P
Peter Guiton Cali
Bothenhampton
T6.1 Ocean 150
I have a 2020 California ocean and it is stored in a safe storage compound, however there is no
Plug sockets near. I am looking for a cordless trickle charger for over wintering , has anybody found one or uses on
Cheers
Peter
Cheers
Peter
Autoexpress did a review in 24 of solar chargers, it might give you some information.
I'm in a similar situation and use the EF Delta 2 plugged into the EHU to keep the batteries topped up. Works great. I keep the EF inside the vehicle and feed the cable out through the sliding window to the external socket.
The CS Free from Ctek will give some top up charge. A friend used one on a mh as he was experiencing some excessive drain in storage. You will need to recharge the CS every so often but it would help reduce the number of times you need to visit the storage site.
Ctek do some great chargers, I have several Mxs'.
Just looked at this one and it looks good. It has an optional 60w solar panel that plugs into it (suggested 1 hour to charge). It's a lot of money, you won't get much change out of £400 with the solar panel. That was on the Ctek site though. The solar panel must be quite good, most of the panels on Amazon are only about 10w.
How much would it cost to install a panel on the roof? Probably cheaper and you don't have to do anything.
Ctek do some great chargers, I have several Mx's.
Yes its pricey. I had assumed the van was in a position that solar wouldn't be an option ie undercover as that is the obvious choice. Don't bother with panels below 40w as they will be rubbish in winter. If solar is an option just go for a 100w+ to aid battery charging all year.
Peter, have you considered a portable solar panel outside and a long lead along with something like VANBITZ battery master that can share the charge between leisure and starter.
