How to make a Beach handle more load on the roof
I bought the strongest 800N. Today I put the 800N and replace the original 450N. I need it for my roof box and wing foil gear alltogether 50kg. Today I tried how Will open only with roof , no roof box. Opening is OK. Almost the same as with the original. But closing the roof is very Hard. You must give a lot of strenght to close it. I did not try with the roof box yet. I hope that Will be better. I think that 800 N is a little to much. I wish i bought 650N.
I use rachet strap to change the gas spring.
Thanks for the advice.
After one month of use, one of the gas struts started leaking oil and consequently lost its function. I contacted the company Hinscha, and they kindly offered to replace it under warranty — free of charge. I sent them photos, and they determined that the struts were installed incorrectly. Apparently, the wider part — the cylinder — should be positioned higher than the narrower part — the rod.
When I receive the new ones (this time I will get 650 Nm), I will replace them and install them the other way around compared to how the original ones were mounted. I hope this will work correctly.
I’m attaching a picture of how I currently have them installed, and also a picture from Hinscha showing how they should be installed.
They wrote:
When installing the new gas springs, please make sure the cylinder is positioned higher than the thin rod. Otherwise, the seal of the cylinder may dry out because the oil cannot reach it. If the seal dries out, it will eventually degrade (this is not visible), causing the gas spring to lose oil.
Good of them to replace under warranty!
Never knew that, so would appear that VW have fitted the roof struts upside down on all beaches at the factory…below video also explains.
Given they spend 99% of the time in the closed (horizontal) position, I suspect it’s not that much of an issue?
Mine are mounted in the wrong way as well then for theee years, no problem yet. My car normally is parked 99% of the time with roof down on an incline where the front is lower than the rear so I guess its the right way for my vehicle.
On suspension mtb the recommendation is to store the bike so that the fork is upside down, then the sealings will last longer as well.
Interesting, mine are (and always have been) mounted 'upside down' as well. Just had a quick look at some of the other manufactures (SCA, Westfalia, Jerba) and they all appear to have the cylinder end fixed to the elevating roof rather than the vehicle body.
So, what about the Gas struts holding the roof bed up or the Tailgate?
I received a new explanation from the manufacturer Hinsch. The previous statement that the gas springs must be turned upside down is NOT CORRECT. They must be installed in the same orientation as the original ones when the car was purchased
I received a new explanation from the manufacturer Hinsch. The previous statement that the gas springs must be turned upside down is NOT CORRECT. They must be installed in the same orientation as the original ones when the car was purchased.
This tilting mechanism causes the gas spring to be positioned in reverse when the roof is closed compared to when it is open. So, when the roof is open (the cylinder is lower than the thin rod), but when the roof is closed, the cylinder is higher than the thin rod. In this position, the lubrication takes place. Since the roof is closed most of the time, the gas springs must be installed as shown in the photo below: (picture of original mounting)
On the inside, gas springs are also often installed, but these are mounted in reverse because they do not have this tilting system and are therefore always positioned with the cylinder on top, both when open and closed.
We have fully documented this information internally and sent a shortened version to our website developer so that this information will also be correctly displayed on our website tomorrow.
Therefore, we recommend that you reinstall the gas springs as they were originally mounted.
PLEASE DO NOT USE THIS INSTRUCTION.
I’m also wary of overloading the pop top roof, knowing that VW only rates the limit at 50 kgs.
Photos below of our double kayak…20 foot long , weighs 37 kg , additionally the roll rack (12 kg ) I’ve made to enable just myself to load onto the roof ( with a hinged T bar with rollers mounted into the tow bar socket).
Total weight with bars 53 kg…. we don’t raise the pop top (electric raise & lower) with kayak… instead just sleep in lower deck…..
I don’t think putting more load on is a problem as long as it’s well spread and you don’t try pushing up an overloaded roof.
I‘ve dropped my roof box in favour of a full length rack, that’s way over the 50kg loaded. I don’t think I could push that up if i wanted too.
I won’t put something stupidly heavy up there like an ikea kitchen though.
I think it’s also worth mentioning that the load needs to be centered and pushed towards the back to make pushing it up easier.
I had my roof box in the middle so I could access it without a ladder. It was a lot easier to push up when it was further back.
I did eventually find the terranger website which had recommendations for roof load and damper combinations. I chose a 590nm damper and made a video of the job. In my test it works well with my 45-50kg load. Hope it’s helpful info.
Hello Andrew, fantastic footage, thanks a lot for this explanation!
I’ve got pretty much the same set up of yours, with a Thule Touring S roofbox, Thule wingbar and Califaktur solar panel, and would like to have the possibility to reach up to 45Kg on the roof while travelling (not going beyond the recommended limit of 50Kg antway). One thing is different: as the solar panel is fixed on the back of the pop-up roof, I have to place the Thule box on the front, likely resting more on the gas springs compared to your one, that is placed right in the middle of the roof.
In such a configuration, would you recommend to go stronger struts, like 650N Hinscha gas springs?
Thank you for your support!
Hey Gwynn81, did you finally get the Hinscha 650N struts? Do they work properly? Any issue when closing the pop-up roof?
Thanks!
Hello folks!
I mounted the 650N Hinscha struts a few days ago and everything worked out properly. No issue at all when closing the pop-up roof: it comes down quite easily, without any particular effort (just a bit more than before).
Thule box on the roof front, while solar panel in the back: with the new struts the roof goes up very smoothly, very good feeling coming from this new setup.
Take care.
