G
Gwynn81
After one month of use, one of the gas struts started leaking oil and consequently lost its function. I contacted the company Hinscha, and they kindly offered to replace it under warranty — free of charge. I sent them photos, and they determined that the struts were installed incorrectly. Apparently, the wider part — the cylinder — should be positioned higher than the narrower part — the rod.I bought the strongest 800N. Today I put the 800N and replace the original 450N. I need it for my roof box and wing foil gear alltogether 50kg. Today I tried how Will open only with roof , no roof box. Opening is OK. Almost the same as with the original. But closing the roof is very Hard. You must give a lot of strenght to close it. I did not try with the roof box yet. I hope that Will be better. I think that 800 N is a little to much. I wish i bought 650N.
I use rachet strap to change the gas spring.
Thanks for the advice.
When I receive the new ones (this time I will get 650 Nm), I will replace them and install them the other way around compared to how the original ones were mounted. I hope this will work correctly.
I’m attaching a picture of how I currently have them installed, and also a picture from Hinscha showing how they should be installed.
