3D printable accessories
Tailgate shower holder
For T6.1, may also fit others.
https://makerworld.com/nl/models/16...t6-1-tailgate-shower-holder#profileId-1787856
Very nice, thanks! I actually printed the upper bed shelves in that collection this morning
Oh - awesome - I thought it will not fit when the roof is folded, but it seems it does - which is great as I dont have to figure out a place to store those :)
It fits, I even have a Brandrup Isotop inside. The only thing is that the slide can’t fully close as you can see in the picture but that’s not a big deal.
This is great.. can you please list what other parts are needed (pipe?, fixing screws..)
Honestly, you are better off just buying the mobility mount from Starlink and mounting with slot bolts to the rail. I did just that, but with a high roof van attached to airline rails on the roof.
Not the cheapest but maybe the best guarantee for success indeed.
In the
In the Starlink Shop in Switzerland it's 12 Chf. I can't even buy lunch for that. Alternatively if you have low profile roof racks you can use the Mini Roof Rack Mount for 16 Chf. I'd say those are cheap.
In the
This is what I see in the Dutch Starlink shop, but this one of officially meant to be mounted through the roof, not on the rails.
It’s meant for that, but as it has bolt holes nothing stops you from using those with bolts to airline rails or other rails like on a Cali. I just used my own airline rail bolts cut to size and drilled the holes slightly larger to fit the M4 bolts. Works perfectly. My dish is going nowhere. I driven at 130Kmh with 30-50kmh side and headwinds and it was rock solid.
Well, the search for a good printer at a reasonable price is giving you headaches and they all have their pros and cons.
I have an Elegoo Centauri Carbon on order (with some extras):
https://eu.elegoo.com/products/centauri-carbon-all-in-one-family-combo
That one does not support multi material yet (that is, having multiple colors or materials ready in an automatic system) but it is scheduled for October (give or take).
I also looked at Bambu Lab X1C or H2D which do support multiple materials already but these are less “open” and more expensive.
Thanks - sorry, I’ve only just seen your reply. Must get notifications switched on…
Wow what a fantastic thread, 3D Printing is alive.
I have recently printed with ABS, that turned out ok for what I was using it for, I need to try Carbon Fibre Filament as ABS just wasn't strong enough
I recently designed and printed a Starlink bracket for my Cali, it was a bit of a 5 min design job as I was going to a festival that weekend. I do have plans to improve the design when I get some timeD46ABA00-7D5A-4004-8F10-04F952130165.JPG
Nice! If you want to post a photo of the end result mounted in your Beach, that would be awesome
Better late than never. Just managed to re-print in PETG as the PLA ones warped due to the heat in the van as can be seen from the last picture.
I recently designed and printed a Starlink bracket for my Cali, it was a bit of a 5 min design job as I was going to a festival that weekend. I do have plans to improve the design when I get some timeView attachment 141053
can you share the file please?
Awesome! Looks great.
I know that problem with PLA. It’s a bit stronger than PETG but can’t withstand the heat, where PETG is better. Alternative could be PETG-CF which is a bit stronger but requires a hardened steel nozzle.
Or if you like the fumes: ABS, ASA, PC.
Top door sliders of kitchen cabinet doors (VW part 7H7098390B)
My T5.2 is a conversion of a Transporter to a Cali lookalike.
The sliders / hinges of the kitchen cabinet doors were VW part 7H7098390A, the steel ones. Unfortunately they were very poorly mounted (just like other parts of the conversion) and two broke.
Nowadays they are replaced by VW part 7H7098390B, which are plastic ones. A repair set was 64,95€ for two of them in the Netherlands. I bought them and one broke during install because of a poorly mounted top rail. I won’t repeat what I said at that moment but both the Lord and a slight reference to the 7th commandment were mentioned.
The cheapest pair I found in Germany sets you back at 43,90€.
Well, as much as I grant someone to earn a living, I think this is too much for two small pieces of plastic.
So, I will design my own and prototype the outcome with different materials for strength.
Once done, I will share that 3D printable design here, but I won’t be selling it to anyone.
It’s these things I’m talking about:
Hi,
Did you designed these parts for 3D-Printing and would you share your results?
I have the same troubles...
Greetings, Chris from Germany
Ooh! Don’t suppose I could have the file too please? Thank you!
Inspired by [mention]Carl_______________ [/mention] when he showed his solution for storing an EcoFlow solar panel underneath the rear seat bench rack (or whatever it’s called) with a 3D printed solution, I decided to get my 3D printer out of the dust and look for usable accessories that I could print without spending a fortune on “official” parts. Not that I don’t grant someone to earn money, but my wallet is becoming an echo well…
In this thread I will share the things I found and printed with photos and the link to the design. Most are not my own design, so I want to give credit upfront to the maker hobbyists out there that came up with these.
I wanted to thank you for your helpful post! I’ve been getting prepped for France and have bought a starlink bracket thanks to you. Plus, I’ve been creating some spice racks!
Kennnyboy
GilesSelby
GilesSelby
daniel_thomason
Alan Andrews
Alan Andrews
daniel_thomason
daniel_thomason
daniel_thomason
