T7 Ocean/Beach window bags - is there still a blind behind?
thehoggmeister
thehoggmeister
Scotland
T7 ocean
I forgot to check this when looking at the T7 Ocean recently.
If you remove the window bag at the rear is there still a pull down blind behind?
Hi, there is no window blind on mine if the bag is removed, the space where the blind would be is taken up by fixings for the bag
Thank you for checking. We will probably take the bag out unless away camping.
I found them a big PITA to refit, so much so that I no longer remove them to fill and just fill them in situ, not sure if anyone has a good knack of putting them back in, I found getting the bottom bits to locate on the pin / popper things tricky not the top toggles..
Agree on this - I found exactly the same and have resorted to packing inside rather than taking out. Those pins are a real pain to feel and find.
Meoncoast
Meoncoast
Chriskend
Chriskend
Chriskend
Norfolk Jim
5K
Magic Bus
Magic Bus
T
Peter Chequers
P
