Kirx
Thank you but I’d prefer someone else to do it, my DIY is lacking in any kind of skill! I’ll still save myself a fortune£13 on eBay, some small torx drivers and half an hour
If you have no inclination or the appropriate skills to fix your sat Nav , try :Thank you but I’d prefer someone else to do it, my DIY is lacking in any kind of skill! I’ll still save myself a fortune
I’m booked in with them on Friday, thanks to this thread, and regained my composure after yesterday’s shocking VW Dealership quote!If you have no inclination or the appropriate skills to fix your sat Nav , try :
Sat Nav systems Chertsey / Surbiton, they offer a postal service, (they tell you hos to remove your unit easily ) I have used them before, Excellent company
SNS - SatNav Systems | Technology Specialists for Volkswagen Group: VW, Audi, Porsche, Lamborghini, Seat, Skoda
SNS - SatNav Systems | Technology Specialists for Volkswagen Group: VW, Audi, Porsche, Lamborghini, Seat, Skodawww.satnavsystems.com
Hamid &Adam are absolute gents, say hi from me, they will treat you well.I’m booked in with them on Friday, thanks to this thread, and regained my composure after yesterday’s shocking VW Dealership quote!
Just to add, huge thanks - @WillSS - I’ve just fixed mine using your method! Saved me hundreds ££.Ok Brett, i‘ve just dug out the the photos, it was actually nearly a year ago looking at them now! Memory a bit rusty but the photos pretty much show the order of things
First the part, here’s the ebay link to the digitiser… no surprises it’s gone up in price like the rest of world. This is supplied from the EU (Germany) but you could take a punt on the cheaper Chinese delivered one (does look a different supplier though). I bought the EU delivered version.
ebay item 115045718856
If this link doesn’t work down the line then just search for “VW digitiser TDO-WVGA0633F00039”
To fit you obviously need to remove the unit, clear the kitchen table and grab your screwdrivers, fairly sure the screws were all of the small torx variety. Then pull it apart to get to just the screen…
No great surprises here, pull off the front knobs, remove any sd cards and just look for the relevant screws…
View attachment 103438View attachment 103439View attachment 103440
Once here you’ll spot a small plastic clip holding each of the two card slot gubbins (below now removed laying on their side, were vertical)
then gently ease up the 2 ribbon connectors and slide them out…
View attachment 103441View attachment 103443View attachment 103444View attachment 103445View attachment 103446View attachment 103447
Basically keep striping it down until you get to the glass unit.
Now get your new screen and after cleaning stick it over the existing one with the supplied 3m edge tape. Yes on top of the exisitng!
You will not get the original one apart as it is bonded throughout to the LCD. It is only 1mm thick and will still fit fine. In the last photo it looks like i helped the ‘fit‘ with a bit of sellotape here! Then put it all back together in reverse order but obviously connect the correct ribbon in. I left the existing one tucked out the way hence this is all completely reversible back to your original condition should you need to go back for any reason!
The end result is it looks and performs as per the original ‘working’ screen.
As said been a year now and mine’s performed perfectply.
Good luck, Will
How much is a replacement unit. We’ve had problems with the the touch screen for a couple of years on a 5 year old California,the L hasn’t worked for a long time on the satnav..You can’t programme satnav on touch screen only on voice control.If you try and touch the satnav screen when it’s running it will no longer move with the route and even jumps to countries all over Europe,you can’t re centralise the screen.The radio programmes jump all over the place too,keeps changing stations .Took it into the van centre they diagnosed that the control unit behind the touchscreen needs replacing at a cost of £2200.I’m not even convinced that it will fix it because the letter L isn’t working.A customer who overheard said to me it sounds rubbish seek a second opinion.Any ideas I don’t want to spend all that to have the satnav still not 100%
This post was so timely, I was putting the old VW head unit back in as hopefully trading our 2016 Ocean in soon. I had put an Alpine Halo 11 in but wanted to keep it. When putting the old VW head unit back on Sunday the touch screen no longer worked! Then, when I woke up Monday, this post was in my emails! I found the new screen on Amazon for £18 with next day delivery and it arrived this morning (Tuesday) I then fitted it to the new unit, using YouTube video. I just put it in and works fine! I am no electronics wizard but having done a few stereo installs it was relatively straightforward.North West repairs.....
Call Rana on 07759 005000
Advanced Repair
17 Preston Street
Bradford
BD7 1JE
Replaced my screen while i waited on T6 Beach in approx 20mins
Mine started with dead spots then was totally unusable
Works top drawer now and has warranty
Great service
Hi WillOk Brett, i‘ve just dug out the the photos, it was actually nearly a year ago looking at them now! Memory a bit rusty but the photos pretty much show the order of things
Good luck, Will
post 84 above?Anyone got a recommendation for someone to fix my satnav who's in the East Midlands/East Anglia/South Yorkshire area? Extra points if up or down the A1
Hi . I'm in Northampton. Just got my touchscreen repaired by Tom at Tab-Tec based near Braunston, Daventry 07300 600990. Really helpful. Took the unit out, replaced the screen, tweaked the software all in 50 minutes. £130 all in. Highly recommendedAnyone got a recommendation for someone to fix my satnav who's in the East Midlands/East Anglia/South Yorkshire area? Extra points if up or down the A1
Breeze did mine back in the spring under wty.Hi all, the screen on my 2017 Cali is suffering from not being responsive to touch. I have the all in plan and have booked it in for a service/MOT at which point I’ll get the screen looked at. My query is has anyone had their screen/unit replaced under the all in plan warranty?
Thanks in advance
Awesome thank you. My warranty expires 6 days after the service is booked in for so I’m crossing my fingers this goes to plan.Yes mine did at breeze stocks may be low so worth getting the dealer to see it b4 your service date so they can get the replacement authorised and on order as even a couple years ago they were in short supply!
Great, thank you. Fingers crossed…Breeze did mine back in the spring under wty.
Yes completed May 2024 under all in plan.Hi all, the screen on my 2017 Cali is suffering from not being responsive to touch. I have the all in plan and have booked it in for a service/MOT at which point I’ll get the screen looked at. My query is has anyone had their screen/unit replaced under the all in plan warranty?
Thanks in advance
Thank you, that’s a great idea. I’ll make a video to show them and definitely won’t be leaving if it’s not working.Yes completed May 2024 under all in plan.
Points to note.
Take a video of you demonstrating faults or be able to demonstrate them to technician tasked with assessing.
Often they will try and “fob you off” with a chargeable software update.
Inability to type in post codes or alpha numeric characters is a pass/fail type of error and if occurring or can be demonstrated will result in a replacement.
Don’t accept a software update as this won’t fix a failed screen digitiser (which is what is preventing screen inputs).
Finally, whatever they do if they say it is fixed, don’t leave the dealership without checking that all your known issues with the screen have been fixed.
