Bradely
You are correct the C and T are connected together but with a resistor in the circuit.Hello, I am new here, own an Ocean T6 registered 2020, fabulous car so far, but I experience some strange fridge behaviour:
- It does not work for more than a couple of minutes off grid (so without engine running or connected to external 230V), and only after repeatedly pressing the fridge button
- It works when the engine is running (though I may have to press the fridge button up to 10 times before it works)
- It works when hooked up to external mains power 230V
I just installed 2 new leisure batteries hoping this would solve the issue but it didn't. Voltage on the display is 12.7V, so far away from the low voltage level threshold.
Another strange thing: last weekend we slept in it for the first time, it was connected to the mains. I set the fridge at level 1 but it kept running the whole night and in the morning a water bottle and the strawberries were completely frozen. So looks like something is wrong with the temperature control as well.
Any ideas what I should do? I'm pretty good at DIY, read posts on faulty Danfoss controllers on the T5, is the same controller on the T6? Can it be reached at all?
