Trojax
So here is a strange one, on a recent trip my son could not open the sliding door from inside, I duly checked that the child lock was off and the door would still not open. In the end I had to open the door from outside. When we tried to close the door it would not close as the lock looked locked.
I did a quick check here before I called out the VW assist and found a BASIC SETTINGS to try so I held the door closed as far as it would go and the pressed the lock button on the key and then opened it. This enabled the door to close however it made a horrible noise on closing. After the shock and checking that nothing was not scratched or chipped. I locked the door and went off.
As the noise has stayed I booked the van in to my friendly VW Van cent who have had the van for 3 days and found that the door latch has failed so when the door is closed the latch is not fully opening hence the noise.
Apparently a broken door latch/lock is not covered by the All in One service plan warranty so wonder if anyone has had a similar issue with this lock......
Terry
Terry
