Rear coil spring
ST111
Glasgow
T5 SE 180
Hi All, I have a 2015 T5 4 motion and recently bought a double axle trailer. My factory fitted removable tow ball is pulling the front of the trailer down, feels like the tow ball is a little low. I was thinking of changing the rear spring from 7H5511115N to one a couple of cm longer. But I cannot find the lengths of the various spring options. Does anyone know where to find the lengths? Has anyone else changed rear springs to increase ride height?
Steve
I changed the rear springs & shocks on my 2015 T5 (not 4 motion) several years ago
At first I just upgraded to some T32 springs from ebay but they lifted the back way more than I wanted.
I did quite a bit of research and at risk of looking a bit sad here is the spreadsheet....
The vans (and springs) have a weight range. 3 for my 2wd and based on the part number above looks like 4 for yours - then for each weight range there were 3 spring types, std, uprated (a longer spring) and heavy duty (a stiffer spring).
The part number you quoted is the std one. I swapped for the heavy duty which lifted the back an extra 10mm or so just because it compressed less under the weight of the van, i suspect the uprated one would add even more height.
For your weight range 4 I think the part numbers are 7H5511115P for the uprated and 7H5511115P for the heavy duty. One thing to watch out for is that some aftermarket springs are a constant diameter wire and don't fit very well into the spring cups. Hope that helps.
I also changed the shocks for heavy duty ones to match the springs.
  • Louis Suspension.xlsx
Steve
Transporter HQ sell Eibach rear balancing springs , that are designed for campervans, maybe a solution?
Typo correction: part numbers are 7H5511115P for the uprated and 7H5511115G for the heavy duty
thank you for the excellent feedback, I will let you know how i get on.
cheers
Steve
Cameron1960
Cameron1960
Cameron1960
G
30K
Grumpy Mike
Grumpy Mike
