Rear Spring replacement
Shadrack
West Wales
T6 Ocean 204
Hi,
I discovered a piece of the plastic coating split on a rear spring. As there are signs of corrosion I think I will need to replace both.
The rear springs seem such a mine field of different types weights etc.
The springs I need have two white dobs of paint which I think are specific for the 2016 204 Cali Ocean. I am struggling to find the correct part number to get replacements.
Please if someone could help and point me in the right direction for part numbers or replacement's
Hi,
This would suggest:
7H5511115N (PLEASE CHECK)​
But please check, I would call the dealer, the springs are dependant on the exact spec of the vehicle inc. options. You can try and look up your PR codes (in handbook and lower dash closing pane) - you will see the PR codes referenced in the diagrams on the weblink above.
Hi,
Click link below. Select year. Select Rear Axle, Scroll down to Suspension.
Many thanks guys, I do appreciate your help. The Two white paint marks and the number ending in 5N seems to be the one.
A great link that Welshgas, very useful.
