Electric roof problem
Thanks, vbk1975! I will manually open the roof and inspect the sensor wiring later today. I replaced all four sensors…..initially front two, one of which was very corroded but got same error so replaced the back ones and still same error. If all the wires are correct, I.e. brown to brown, red to red, should I try swapping the wiring round on one side, front and back?
I would look at the hardware menu (link above), then readings are always valid regardless if a fault code is logged or not.
Sorry……just seen your reply above also…..thank you…..I’ll take a look at the hardware menu when I’m back later
Worth reading to the end of the thread as well, it might help you
Hi tbk1975! I followed the instructions and did the following:
  • with roof down pulled the 30amp fuse; left it a couple of minutes; put fuse back; ignition off; AN8 and AN9 both 0
  • Ignition on; flashing roof icon; AN8 and AN9 both 255
  • manually raised roof directly connecting motor; AN8 = 105; AN9 = 255, no errors
  • Checked sensors, all wired red to red and brown to brown.
  • Lowered roof half way using control unit, no error, AN8 and AN9 both 105
  • Lowered roof further using control unit and didn’t quite fully shut, error 1000, both AN8 and AN9 255
Any further suggestions greatly appreciated…..thank you ☺️
i think one of the closed sensors is either defective or there is a wiring issue. I think the system is recognising one closed sensor but not the other one and that is what triggers the error . From memory the closed sensor is the one to the rear of the ram / rear of the vehicle. Worth just checking they are both fully seated and hasn't popped out and/or no damage to the sensor where the cable goes in. Also just double check no stray strands of wiring in the joints touching the other wire. (although this would probably mean a constant fault)
Thanks so much for swift response again!! I can confirm that all sensors are seated correctly and wiring isolated…..all sensors are brand new from BMW…….do you know if there is a way of testing the sensors? Just to mention, when the roof was open, I tried putting a metal object (socket bits) on each sensor and checked the hardware readings but values didn’t change?
The sensors are two wire Hall effect. So they change the amount of current they flow when not active and active. I think 12-17mA when active. The sensors need a good chunk of steel to get them to trigger. I have 3mm steel bar on my test rig. A M10/12 steel nut works but very hit or miss on anything not pure ferrous metal and a big enough surface area. Because the ECU uses both sides to determine the state, you won’t get one sensor to trigger a warning.
Hi, the only thing that occurs to me is that there was one extra complication other than red-to-red and brown-to-brown. At one point there were two wires. Could this be the problem? See below pic
The only other thing I wonder about is there a particular bit of the roof that goes close to the sensors to activate the circuit? Is anything looking identical on both sides of the van.
VBK knows a lot more about this than I ever will. I still think I was lucky and fortunate to have people push me on when it didn’t work first time.
Thanks vbk1975…..I wasn’t able to try yesterday due to rain but I have a large crowbar and a bolster that will hopefully give a reading…..will try later.
Hi Lambeth Cali……thank you for your reply….I could only see the red and brown wires on the rear sensors when I swapped them out……I didn’t undo the existing tape holding all the wires together though as had enough length of the red and brown wires when I snipped the old sensor off……are the additional wires you mention under the tape?
Does this make it a bit clearer. The joint you can see is the common sensor feed that is spliced at the ram.
{EDIT} Just an example but the splice will probably look like this (just an example not the Cali) - it is ultrasonically welded and will be taped or heat shrink.
Ah…..thanks so much vbk175……that makes perfect sense……based on this, I guess it is worth me removing the tape to inspect where the common sensor feeds are spliced……I’ll take a look later…..thanks again.
Hi vbk1975 and Lambeth Cali,
Sorry for delay getting back…..was away over bank holiday and just had a chance to take another look at my van.
I manually raised the roof again and tried putting a lump hammer one side on the rear sensor, a heavy duty bolster on the rear sensor on the other side. When I checked the hardware menu, there was no change to AN8/9 values, no matter where I placed the hammer / bolster!……is there something I am doing wrong? Just to mention, I have had a look at the wiring and everything looks to be ok…….any help really appreciated…..thanks again
If you have one of the old sensors (the one looks like it is in best condition), then perhaps swap the rear sensors out one at a time using the old one and do one side at a time. I know this is a pain, but perhaps just use choc wiring terminal blocks to do a quick prove out before committing. If nothing else it will try to eliminate a faulty new sensor.
Hi vbk1975
Thank you for your swift reply and suggestion. Unfortunately, I cut the wires close to the old sensors, so not sure if I will be able to rewire them. However, I have had a small breakthrough in that by using small speaker magnets, I was able to get some readings from the sensors!! With the roof half way down, both AN8 and AN9 show 104 (as expected) if I activate just the rear left sensor, both AN8 and AN9 show 255 and get the error. After resetting, rear left back deactivated and with roof in same position, when I try to activate the rear right sensor only, nothing happens, both AN8 and AN9 values show 104, meaning this must be the one failing!! Regarding the front ones, using the same approach, it appears the front left is not working but this does not cause an error as front right alone seems to be ok. Based on this, I’m going to try swapping front and back right as I know front right works……fingers crossed and will let you know…..thanks again!!
Hi vbk1975
Quick update……I managed to wire up one of the old sensors and tested it by switching wires and applying magnet…..sensor gave a reading, so swapped out the faulty one but still the same error occurs I can now get the error when applying the magnet to either side at a time but same error when both rear sensors activated! Could the issue be with the roof ECU or control panel? Any help greatly appreciated as the little hair I have left is rapidly depleting
Can you put the old sensor back on the ram and see if it works with the rams rather than magnets. The sensors have magnets in them, so they are designed to react to the internal of the ram. I am not hopeful but it would be a shame to start chasing ghosts.
It could be the Roof ECU input although I don’t remember anyone with a roof ECU fault, but never say never.
Roof Panel, again it could be, although from memory both the AN signals have reacted to changes.
I am equally frustrated!!
Really appreciate your assistance :)
I put the old sensor on the ram but unfortunately still no luck :-(
I have stripped the wire back a bit more on all sensors / ecu wires and have used terminal connectors to make sure of good connection, as suggested. Tomorrow I’m going to switch the sensors around to try and identify faulty ones. Fingers crossed!! Thanks so much again!!
I admire your resolve. I dunno.
For £50 I would be tempted to get 4 new sensors and start again.
Ok, so….with roof at mid point, I first pulled the two rear sensors from the ram and placed directly on ferrous metal to activate and got error; I then tried activating each side individually and got error both times, suggesting that the sensors are both returning something; I then tried swapping out each side for one of my old sensors; same result each time. Very odd but maybe I’ve just been unlucky with the new sensors? As you suggest, maybe best for me to buy 4 new sensors and try again……no harm in having spares if it turns out it is something else :) Thanks again for your help!!
Quick question……do you know of a way to test the sensors using a multimeter?
So if you can put a sensitive current meter into the return line circuit. the sensor should be 12-17mA when active. So if you can put the meter with one probe connected to the sensor brown wire and the other probe on the vehicle brown wire ( with the brown wires not connected - just for clarity) and have the meter in the mA setting.
Thanks so much as always, vbk1975!
Based on this, I wired so I could test the rear sensors with the roof down, I.e. disconnected sensor from the vehicle brown wire, then extended sensor and vehicle brown wire so I could put multimeter between the two with roof shut……wires poking out from under the shut roof. I tested each side with the roof down and error showing…..both just showed 0 amps! I also checked voltage, which there was. I assume that both showing 0 amps indicates faulty sensors…..does this sound feasible? Thanks so much again!!
So real world numbers with sensors from BMW directly
^ Sensor active, ie lump of metal in place, this is uncalibrated meter - mA
^ Sensor in loop but not active
Thanks so much for the above details and quick update……partial success!! I received 4 new sensors……connected the rear ones but didn’t fix to ram to avoid any chance of damaging them. Put both on ferrous metal and with roof half up, still got error. I then did the same for the front ones (not connected to ferrous metal) and no error with roof closed icon……success! I tested with the existing rear sensors again and got same result so left in place. I then put roof fully up using control panel…..all fine. I then tested closing the roof……..it does fully close with no error but the control panel still says roof up :-( Based on this, I’m thinking that the sensors are functioning but rear ones not registering when roof closed. I will try swapping the rear ones out for new ones but just started raining, so will need to wait! Thanks so much again for all your help…..getting there!!
Well…..it is fixed!!! I (gently!) wedged a rolled up piece of electrical tape between the hydraulic pipe and the rear sensor to make sure it is held in place……and it worked!! Guess I was just unlucky that one of the original new sensors was faulty! Thank you so much for all your help…..wouldn’t have been able to do it without your advice :)
John Herbert
Max-Felix
Max-Felix
philcod
5K
Jon Hudd
georgemojo
Corradobrit
Corradobrit
tedgina
T
D
choplee
