V
vbk1975
I would look at the hardware menu (link above), then readings are always valid regardless if a fault code is logged or not.Thanks, vbk1975! I will manually open the roof and inspect the sensor wiring later today. I replaced all four sensors…..initially front two, one of which was very corroded but got same error so replaced the back ones and still same error. If all the wires are correct, I.e. brown to brown, red to red, should I try swapping the wiring round on one side, front and back?
