Grand California 600 owners manual pdf?
Soton Campers
Soton Campers
Southampton Campers
Southampton
Hello everyone.
I don't suppose anybody has an electronic copy of the Grand California 600 user manual they could share or point me in the direction of where to obtain a copy, please?
Thank you.
If you have a vehicle vin number you can access an electronic copy on the VW website.
I know it says car but it works using the Vin number on both my vans. It does not work using the registration number. - that results in a message about it being cars only with commercial vehicles not being supported.
It is not in an easy format to print, but if there is something in particular I could PDF a few pages if needed.
Does anyone have the electrical wiring diagram ?
Thank you Gary. these 2 I had. I was hopping more in detail like the picture below (it is from a different car).
What I want to know is the following:
If battery goes to 0, but then solar panel starts to work, or I start the engine, or I connect the exterior plug to charging, then Control unit "sees" that charging and the % starts to increase and everything is fine. But if I use Ecoflow Alternator and I charge the battery from an exterior Ecoflow battery the control unit does not see the battery is being charged so it will not allow any usage. I believe there is something in the wiring that I can replicate on my connection
Where did you connect the Ecoflow. (Negative). It's probably not going through the leisure battery shunt which is under the bonnet. Just a thought.
How have you connected the Alternator Charger to the leisure battery?
yes, the Ecoflow alternator goes directly to the leisure battery under the bonnet
The +ve has to be to the +ve and the -ve to the chassis, if you have attached -ve directly to the -ve you are bypassing the current shunt so the GC will not be measuring any charge flowing into or out of the battery due the alternator charger. Just for avoidance of doubt - the leisure battery is the one in the engine bay, not the one under the left side (UK passenger) seat.
we connected -ve to -ve (under the bonnet where the shunt is, so the leasure battery). We will try to connect -ve to chassis and check. Thank you very much!
I can't offer any more advice, I'll leave this th Gordon.
Hello
Do you know where is the fuse for the 5V USB plugs ?
