andrzej.lipka
Hi,
My first post here. I've looked through the whole forum and the responses where not 100% clear, so hence my question, sorry if it was answered somewhere.
My situation: I have a 6.1 Cali Ocean 2 years. Didn't know much when I bought it (now I do) and I asked a company that does custom van conversions to install solar for me. They installed it (160W) but they connected the Victron to the front (under driver seat) leisure battery, they didn't know the california (neither did I back then) and didn't know about the rear leisure battery..
Ofc now the control display panel is not aware of charging which sometimes (rarely) results in the panel thinking its empty or close to empty when I can see in victron and voltage its fine. I understand this is due to the shunt and connecting of the victron.
Now my questions are:
Thanks in advance for any tips,
Andrew
PS: Had I known more I would have bought @Roger Donoghue solar set, but back then I was a total noob
- Can I fix the issue without moving the victron to back and connecting to back? If so, how? I read that the negative from victron should be connected to chassis (ground) not to the negative terminal of battery, but my guy from the van says that's never the case.
- If I need to move the victron to back, how do I connect it (negative from MPPT to chasis instead of back battery negative terminal?) - is there any good manual to do it? Will that allow the panel to see the amps going into the battery? (without that the Cali will still sometimes think its empty/near empty).
- Is there any way to workaround the issue, like reset the control panel so it would just look at battery voltage (which is fine) instead of historical amp readouts (which miss the solar charging)?
Andrew
