miata63
Assignment of the fuses in the instrument panel (fuse holders C and B)
| № | Amps | Function/component |
| Fuse holder B | ||
| SB1 | 25A | Fresh air blower isolation relay |
| SB1 | 30A | 2003: Rear blower Bitron regulation motor Fresh air blower isolation relay X-contact relay 2004-2009: Rear blower Bitron regulation motor |
| SB2 | 5A | Steering angle sender |
| SB3 | 10A | Onboard power supply control unit |
| SB4 | 10A | Headlight range control regulator Left headlight range control motor Right headlight range control motor |
| SB5 | 15A | Left headlight twin filament bulb Left headlight dipped beam bulb Special vehicle fuse 3 |
| SB6 | 15A | Left headlight twin filament bulb Left main beam bulb Special vehicle fuse 6 |
| SB7 | 15A | Onboard power supply control unit (interior light) |
| SB8 | 5A | 16-pin connector, diagnostic connector |
| SB9 | 10A/15A | Brake light switch |
| SB10 | 5A/10A | Intermittent wiper switch Rear wiper switch |
| SB11 | 5A | Number plate light Switches and instruments illumination regulator (2003) |
| SB12 | 15A | Cigarette lighter |
| SB13 | 5A | 2003-2004: Brake light additional relay 2004-2009: Airbag control unit |
| SB14 | 30A | 2003-2006: Fresh air blower switch Air conditioning system switch Auxiliary coolant heater relay Front blower Bitron regulation motor 2008-2009: Headlight dipper/flasher switch |
| SB15 | 7,5A | Air conditioning system switch Fresh air/air recirculation flap switch (2004-2009) Rear fresh air blower switch (2004-2009) Climatronic control unit Air conditioning system compressor regulating valve |
| SB16 | 5A | Onboard power supply control unit |
| SB17 | 5A | Rear fog light cut-out contact switch Rear fog light warning lamp Rear left fog light bulb Trailer socket |
| SB18 | 5A | Control unit in dash panel insert |
| SB19 | 5A | Operating and display unit for camping equipment Control unit in dash panel insert Control unit with display for radio and navigation system Onboard power supply control unit Roof hydraulics control unit Radio Special vehicle fuse 1 |
| SB20 | 5A | Left side light bulb Left tail light bulb Left brake and tail light bulb 10-pin connector, purple Trailer socket |
| SB21 | 5A | Right tail light bulb Right side light bulb Right brake and tail light bulb Trailer socket |
| SB22 | 7,5A/10A | Control unit in dash panel insert Front passenger side airbag deactivated warning lamp 16-pin connector, diagnostic connector 16-pin connector, diagnostic connector 2 |
| SB23 | 25A/30A/40A | Starter |
| SB23 | 5A | Starter inhibitor relay, 10-pin connector, yellow |
| SB23 | 25A | Trailer socket (2003) |
| SB24 | 5A | Steering angle sender |
| SB25 | 5A | Air conditioning system switch Fresh air/air recirculation flap switch Climatronic control unit |
| SB26 | 30A | Lighting switch |
| SB27 | 15A | Right headlight twin filament bulb Right headlight dipped beam bulb Special vehicle fuse 4 |
| SB28 | 15A | Main beam warning lamp Right headlight twin filament bulb Right main beam bulb Special vehicle fuse 7 |
| SB29 | 10A | 2004-2009: Dual signal inverter relay |
| SB30 | 10A | Rear window wiper motor Rear left wing door window wiper motor Rear right wing door window wiper motor Left washer jet heater element Right washer jet heater element |
| SB31 | 30A | Onboard power supply control unit (signal horn) |
| SB32 | 25A | Onboard power supply control unit (windscreen wiper motor) |
| SB33 | 15A | Control unit with display for radio and navigation system Traffic information control unit Radio |
| SB34 | 25A | 2003: Speedometer sender Air mass meter Automatic gearbox relay Engine control unit 2004-2009: Automatic gearbox relay Positive connection 1 (15), in engine harness Fuses on fuse holder D (engine compartment): №3, 12, 14, 15, 16, 17, 19, 20, 24 |
| SB35 | 5A | Instruments illumination |
| SB36 | 25A | Onboard power supply control unit (turn signal) |
| Fuse holder C | ||
| SC1 | 25A/15A | 2003: 12V socket 2 2004-2009: Trailer socket |
| SC2 | 5A | Interior monitor send and receive module (2003) Interior monitor send and receive module 2 Anti-theft and tilt system control unit (2004-2009) |
| SC3 | 5A | 2003-2007: Right auxiliary blower Left auxiliary blower |
| SC3 | 30A | 2008-2009: Onboard power supply control unit (heated rear window |
| SC4 | 10A/15A | 2003: 12V socket 3 2004-2006: Four-wheel drive control unit 2007-2009: Rear differential lock switch Differential lock control unit Four-wheel drive control unit |
| SC5 | 10A/15A | 2003: Refrigerator box 2004-2009: 6-pin connector, grey |
| SC6 | 5A | Oil level and oil temperature sender |
| SC7 | 10A | 2003: Switch-over relay 1 for roof ventilator 2004-2009: Positive connection -6- (30), in main wiring harrness (roof ventilator) |
| SC7 | 15A | 2005-2009: 12V socket 4 |
| SC8 | 5A | Parking aid control unit |
| SC9 | 5A | Multifunction steering wheel control unit |
| SC10 | 30A | Amplifier |
| SC11 | 15A | 2004-2009: Rear lid control unit |
| SC11 | 20A | Alarm horn (2004-2009) Convenience system central control unit Left sliding door control unit Rear lid control unit Right sliding door control unit |
| SC12 | 5A/10A | 2003: Auxiliary coolant heater relay Brake light additional relay 2004-2009: Brake light additional relay |
| SC13 | 5A | Cruise control system switch Operating unit in steering wheel Airbag coil connector and return spring with slip ring |
| SC14 | 5A | Mobile telephone operating electronics control unit |
| SC15 | 5A | Gearshift indicator control unit |
| SC16 | 5A | Control unit with display for radio and navigation system Mobile telephone operating electronics control unit (2004-2006) |
| SC17 | 5A/7,5A | Onboard power supply control unit (interior light) Positive connection -1- (30), in main wiring harrness Rear Climatronic operating and display unit (2003-2004) |
| SC18 | 5A | Rear fresh air blower switch |
| SC18 | 5A | 2004-2009: Rear Climatronic operating and display unit |
| SC19 | 5A | Automatic anti-dazzle interior mirror |
| SC20 | 10A | Onboard power supply control unit (heated exterior mirror) |
| SC21 | 5A | 2003: Interior monitor send and receive module 1 2004-2009: Anti-theft and tilt system control unit |
| SC22 | 5A | High-pressure sender Air quality sensor |
| SC23 | 5A/10A | Operating and display unit for camping equipment Auxiliary heater operating and display unit Residual heat relay Remote control receiver for auxiliary coolant heater |
| SC24 | 5A/7,5A | 2003-2004: Operating and display unit for camping equipment 2004-2009: Positive connection in roof wiring harness (interior lighting) |
| SC25 | 15A/25A | Heated driver seat regulator Heated front passenger seat regulator Heated front seats control unit Heated front passenger control unit Front passenger seat temperature sensor (2003) |
| SC26 | 10A | Tachograph (models with tachograph) |
| SC26 | 15A | 2004-2009: 12V socket 2 (Multivan without tachograph and second battery) |
| SC27 | 15A | Left fog light bulb Right fog light bulb Special vehicle fuse |
| SC28 | 5A | Mirror adjustment switch Driver door control unit (2006-2009) |
| SC29 | 25A | Auxiliary heater control unit |
| SC30 | 5A | Operating and display unit for camping equipment |
| SC30 | 5A | Auxiliary coolant heater relay |
| SC31 | 25A | Sliding sunroof adjustment control unit |
| SC31 | 5A | 2006-2009: Onboard supply charger unit (camper only) |
| SC32 | 20A | Headlight washer system relay |
| SC33 | 5A | Tachograph (models with tachograph) |
| SC33 | 15A | Tachograph (models with tachograph) Folding exterior mirror control unit (models with tachograph and electric folding exterior mirror) |
| SC33 | 15A | Folding exterior mirror control unit (2006-2009) |
| SC34 | 10A/15A/20A/25A | 2003: Vacuum pump for brakes 2004: Trailer socket 2004-2009: 12V socket 3 |
| SC35 | 10A | Onboard supply control unit (reversing light models with automatic gearbox) |
| SC36 | 5A/15A | 2003-2004: 12V socket 4 2004-2009: Operating and display unit for camping equipment 10-pin connector, purple (models with electric interface only (UF1)) |
