Replacing AGM battery with a LiFePO4 - blog by someone who’s just swapped it
Mr T
Mr T
Chris
West Oxfordshire
Grand California 600
Found this, which is interesting to see how someone has just swapped out the AGM for a LiFePO4
Just found this video very interesting as I also looked at possibly changing when batteries failed.Guys YouTube name is zico Torre
Looks interesting as its a direct replacement without any faff, didn't think this was possible. I might consider this once the current agm battery starts deteriorating.
Bit off work involved but great effort from him doing all the hard work.Not sure reason vw california don't come with this type of set up from factory now.
Cost
Has anybody successfully done a straight plug and play swap with a LiFePO4 for their Grand Cali? I have read through grandcali.com blog and they seemed to just take out the agm and drop in the lithium with the cold weather tech with no issues……I am looking to change my agm and very tempted if I have got the U.K. equivalent battery priced correctly at approx £600…..or I currently have an ecoflow delta max and could just get a short EHU cable and top the current leisure battery up from that!
Hi Dave, I think a few have done it but it’s not without compromise. You can change the charging profile of the solar mppt so that’s not a big issue, but from what I understand if you just drop one in you’ll have issues charging it from the alternator, and most people report having to press the max charge button to get it charged due to its high charge rates I believe.
Also it will not display correctly on the control panel, as it’s configured for an agm. Again this can be changed with the right skills and equipment, but not easy.
I personally am still not convinced that they are a simple drop in replacement based on these things, ignoring the temperature concerns that occasionally get raised
I would suggest you think carefully about what your actual power requirements are - what you’ll be consuming. If you want off grid 230v then this battery solution will onviously not help.
Lots to consider.
I’ve added a 100ah LiFePO4 in the rear cupboard with a Victron dc-dc charger.
I can select either battery, original agm or LiFePO4. The solar tops up the AGM and when this is above 80% it then tops up the LiFePO4.
I didn’t feel the need for any off grid 230v so this solution works well for me and gives me piece of mind at either end of the season when there is less sun about to top up via solar. Also gives me a total useable 145ah’s.
Lots to consider.
Hi Chris, appreciate the detailed reply and like the sound of your set up. Is this something you did yourself or did you take it somewhere to install the lithium set up? Thanks again, Dave
Lots to consider.
Let me see if I understand your setup correctly. Mppt is connected to the AGM, then there is a DC DC charger, that transfers energy from the AGM to the lifepo4 after the AGM reaches 80%. Is that right? How do you use energy stored in lifepo4 then?
I assume appliances are connected to the original AGM battery?
I have replaced the on/off switch in the electrical cupboard with a 3 position switch so I can chose if I want to power the 12v circuit via the LifePo4 battery or the original AGM.
I leave it selected on the LifePo4.
Thanks! I will consider doing the same thing.
J'ai remplacé l'interrupteur marche/arrêt de l'armoire électrique par un interrupteur à 3 positions afin de pouvoir choisir si je veux alimenter le circuit 12v via la batterie LifePo4 ou l'AGM d'origine.
Je le laisse sélectionné sur le LifePo4.
Bonsoir Monsieur T, j'aimerais savoir si vous avez un schéma du câblage électrique ainsi que des photos ou autre chose qui pourrait m'aider à reproduire vos installations ?
Bien cordialement
Julien
After buying our 680 I contacted a number of lithium battery suppliers, all of whom recommended not to fit a battery under the bonnet. We've ended up with a Bluetti 180P and have recently fitted a Bluetti Charger 1 which recharges the 180P via the alternator/starter battery.
I have the smaller california a d space is a premium. After looking into ways to change I also decided to fit the ac180p and the bluetti charger 1.works great leaving two independent supplies and allowing leisure battery to concentrate on keeping the beers chilled and the wife warm.Bluetti doing kettle toaster breville and phone charging .no need for camp sites anymore.Happy
The bluetti 180 is £500 on Amazon at the moment
AC180P
  • 1800W (Surge 2700W) Battery capacity 1440Wh
AC180
  • 1800W (Surge 2700W) Battery capacity 1152Wh
Hi Chris, I assume by the fact that the solar charges both batteries that you have connected your b2b to the AGM leisure battery under the bonnet. I would assume also that if you hook up that will charge both batteries using the same wiring but different power source. Did you run a new cable between the BtoB and the AGM leisure battery ? Not trying to catch you out just understand.
The solar panel only charges the AGM. The AGM is then adding charge to the lifepo4 battery.
when it is above a set voltage via the Victron dc-dc charger.
When on mains hookup the AGM is charged by the battery charger and then the AGM will add charge to the lifepo4 again when the agm is above a set voltage.
From front to back is original wiring. With the Victron 30a dc-dc I’m using the standard wiring is more than adequate.
What did you set the BtoB to kick in at 12.5v? Did you reduce the current draw also? Again just trying to get my head around what people have already done that works.
Shutdown voltage is 12.65v on the DC-DC you wouldn’t want it kicking in at 12.5v as that’s too low! Needs to be off by then.
