G
gothmog827
Hello, I have seen that prices and options for LiFePO4 have come a long way this year.
I am looking to make the conversion to LiFePO4 from current AGM batteries.
I have a T4 California 1992, with the separation relay in the compartment by the left rear wheel.
Based on the information I have found in my research and this post, I will be needing to switch the separation relay with a DC-DC charger (charging booster).
I still have installed the original charger for EHU, which, as I am understanding, will not need to be changed?
So it is as simple as this?
We already have a solar panel installed with a Victron MPPT charger that has the option for a LiFePO4 profile.
Here are the options I have found on the market, so I wanted to confirm if these products would be recommended:
Lithium Battery:
We have the option to get 1x150 for 350 euros, or 2x100 for 430 euros.
https://es.eco-worthy.com/collectio...bateria-litio-lifepo4-12v-150ah-con-bluetooth
Dc-Dc charger:
1) https://eu.renogy.com/12v-40a-dc-to-…214%22%7D%5D%7D
2) https://es.eco-worthy.com/products/40a-d…=42332239429838
The advantage of the 2nd one is solar can also be attached, but as I said, we already have the solar installed.
This means the conversion (including the battery) can be made for a total of 450 euros (for 150A) or 530 for (200A).
Between options of 20A and 40A, which would you pick?
Are these above options suitable for the installation?
Lithium Battery:
Dc-Dc charger:
