Maeve
Hi Webbah, I love your build thread! I am going to become the proud owner of a 2022 CJ on Friday up from a 2018 4Motion Ocean, my specs are identical to yours on the CJ just a later year, in this post I noticed the EVE on the wall, do you have that wired into your heating system and if yes, how did you do it? Have you found a way to remotely start the heating?A few days ago there was decent sun and I decided to run some tests with my solar setup and a constant load of ~250 watts with my Zero Breeze air conditioner going. The van can get quite hot in the sun and I was curious how my setup would handle this and wanted to present the data in this thread.
Here are the devices I have installed for energy requirements:
- 2 LifePo4 Lithium batteries - 120Ah each for 240Ah total of leisure battery capacity
- Victron MPPT Charge controllers - 2 of them. 1 for my integrated solar and 1 for external solar via MC4 connectors
- Victron Charge Booster 30A - To charge the batteries quickly when the alternator/engine is on
- Victron 1600 watt Multiplus II Compact inverter - With all internal AC sockets rewired directly to the inverter for convenience
- Integrated solar - 2 panels of 85 watts each for a total of 170 watts
- External solar - PowerOak 420S panel with 420 watts when I need more juice
I use a lot of power as I "work from van" instead of working from home. This allows the freedom to choose a nice and different view whenever I want and is the perfect mobile office.
I also prefer to cook, make coffee (Nespresso), charge my Evolve Hadean Bamboo electric skateboard, and all my gadgets like Macbook Pro, iPad, iPhone, etc.
This test was using conducted with my ZeroBreeze AC unit as it uses 250 watts constant on it's highest setting and I could judge how well it will work on those hot/sunny days.
I have apps to view all the devices so let's dive in:
Victron app to view all Victron devices. In addition to those listed in "My Devices" I also have the 1,600. watt inverter but this firmware doesn't support grouping just yet. Ignore the "Eddy" devices as this was another van close to me and in range:
The ZeroBreeze is on and at full power as we can see in the inverter:
249 watts which is to be expected. It's currently 35C in the highest point of my van when I started the test (quite warm for me):
We can see the current output of both my integrated and external solar panels via the Victron app:
View attachment 98663View attachment 98661
I'm currently getting about 320 watts total from both out of a maximum of 590 watts in perfect conditions. Considering there are scattered clouds this is ok for this test.
Looking at the load directly on the batteries (in parallel) show's a different picture as this includes all 12V consumers, of which I am also charging my Macbook Pro, have 4 dashcams, and have the refrigerator set on setting 4:
Conclusion: I'm very pleased with this setup! It should be no issue off grid at all and with hot/sunny days I can use my ZeroBreeze AC to cool things down without issue.
