Roof won’t open or close.
nick castree
nick castree
Wirral
T7 California Ocean 4 Motion
I have a T5 California, 2013 Reg. The control panel is telling me that the roof is open and pinging every time I move off. i’m pretty sure it’s the sensors and I have it booked in for a diagnostic unfortunately not until the 13th of March.
The problem I have is it the roof won’t open or close the motor is just not running. I’ve checked all the 30 amp fuses under the passenger seat and they seem okay. I’ve also gone into the VW diagnostic to try to clear the fault to no avail.
I would like to try to resolve the issue before it goes in for the sensor replacement if only to alleviate extra cost.
Any ideas?
Any ideas?
I'm afraid the 2 faults are connected. Due to a sensor failing the hydraulic pump won't work as the controller doesn't know where the roof is, in effect.
I'm afraid you will be in for a hefty bill, courtesy of VW, as they won't replace the sensors but the whole wiring loom. Expect £1500 or so, or more if they don't fancy the job.
But you could visit Kernow Transporters in Cornwall and have it all sorted for around about £500 in 1/2 a day.
Any ideas?
Hi you could try Mark Volkvans in derbyshire.He knows his way around this problem,find him on facebook.He did ours last year in about 3 hours.
Thank you for your reply. I was expecting that response just need to bite the bullet. We’ve had the van for ten years so need to accept these bills. I think I may explore the Kernow route.
We had a similar problem due to our sensors failing. Fortunately the roof failed when it was in the open position and we had access to the sensors. Replaced with 4off BMW cabriolet Mk2 sensors bought on eBay (£100.00) https://order.ebay.co.uk/ord/show?orderId=13-11597-99386&purchaseOrderId=13-1159-799385
The hardest part was disconnecting all three batteries x2 leisure and x1 main engine compartment - took around 4hrs for whole job. There are discussions on the forum how to do it, I’ll see if I can find a link for you.
Kernow (Cornwall) or Mark @volksvans (near Matlock) will both do a great job at a fair price on replacing your roof sensors just depends who's closer to you.
Mark@Volksvans
I was recently quotes £2700 for the job by VW Cowfold.
£200 just for the investigation, after I told them what I suspected the problem was.
Kernow are way less than £500 and takes about 2 - 3 hours.
Any ideas?
First things first is does it look like the roof is down level and not sticking up on one side? To my mind that is the job the sensors do to ensure the roof does not get lifted on one side only following a hydraulic actuator failure. This would distress the roof and mechanism.
My advice is to do it yourself if you feel able. I did a lot of research on this forum and found some good online info from VW themselves that explains how the different modules that control the roof are connected.
My neighbour is a retired auto electrician and his view and mine was battery disconnection is not necessary so I went this way and saved a lot of time. Lots of others believe the batteries should be disconnected though so please don’t do it my way without assessing your own risk.
You have to take the camper controller to bits, take off a sun visor and peel back the head lining so the hydraulic motor is exposed. Then make up an insulated connector with 2 long wires and connect this to the motor. Then using a 12v power supply (I used a spare car battery) lift the roof slightly and check it’s going up equally on both sides. It was a great relief when I heard the motor running and the roof raising. Once fully raised which you know by the familiar sound the motor makes at the top you’re free to get at the sensors. I bought all four but struggled to fit one of the rear ones so left that with the original.
After that the roof went up and down with no problems and has been fine since with no alarms. One lesson learned for me was when this first started to go wrong the roof would still operate so if this happens again I will swap the sensors straight away.
Mark is brilliant, did mine last Easter, nice pub stopover close to him too, £350 I bought the sensors from BMW at £50. Much cheaper and much more trusted than VW Dealers, who will make a meal of it and charge over £1500.
Mark’s is on FB - Markvolks - great chap, cleared the camper drains too, whilst he was at it.
Mark’s is on FB - Mark Volksvans - great chap, cleared the camper drains too, whilst he was at it.
Any ideas?
Any ideas?
Check this:
or this:
Any ideas?
Hi,
I replaced all four sensors myself (£15 each from BMW). A bit of a faf dropping the front of the roof space and the hydraulic motor to power up the actuating mechanism, but ok for a reasonably proficient diy mechanic…. And I didn’t disconnect the batteries, just careful not to short anything.
Previous forums are a good help for the procedure…. Good luck or take the advice of others and access the Cheaper options… I believe VW will only replace the entire wiring loom in the roof, hence the price!
