Leaking side window
Noticed a small amount of water in the cupboard under the hob this morning. Had some pretty heavy rain overnight, is this likely to be a leaky side window? Couldn’t see any evidence of ingress around the window itself. There are some drops along the back panel and a couple of pools along the metal trim.
Check along the top of the waste water tank for evidence of a leak, it's best if you take the cutlery.drawer out for a good view.
I found cleaning the window rubber seals ans mating faces with silicon spray on a cloth made a bit difference.
To test the window drain, the small hole in the drain slot near the front, use a syringe, water should exit below the window.
Worked a treat for me.
Hi
So my husband and I are about to embark on your solution for leaking into kitchen cupboards.
Few questions if that’s ok?
What size plastic tube did you use? And also when you ref drilling, what did you need to drill? (Apart from drilling into waste pipe).
Would the pipe not just push through and come out back of kitchen (obviously going thru faulty flap drain thing)
Also I presume you had to take sliding window out to access the second drain hole.
Where did you join the two pipes before fitting it into waste pipe?
I hope you don’t mind me asking. Desperately trying to avoid replacement window!
Hi
Best test is to use a syringe and direct water down the drain hole.
I would focus on the faulty drain rather than the window rubber/seal. Hard to believe that VW have not sorted this yet! My 2013 T5.1 had the side window replaced 6 years ago and the flaw in the drain was obvious well before that.
Hi do you mind me asking if you happen to know if the latest sliding window (whole unit) kitchen side would be compatible with my 2012 5.1 se?
I have seen new one (genuine) for sale online (considerably cheaper than VW want to charge me) that says it’s compatible with T6 and 6.1. I thought they all fitted eachother?
Also thanks for your very useful explanation with regards the dreaded leaky window situation. It helped me diagnose and also attempt to trouble shoot my leaking windows.
I think there are a number of variations in glass tint etc. I would advise going to a dealers and asking for the part number of the one for your particular VIN and then ask the vendor of the part number of the one that is for sale. If they are the same you stand a chance of getting the correct one.
I think, if you investigate the plastic parts that make up the drain system on these windows whilst it's out of the vehicle you may find that you can fix the leak problem by carefully bonding the parts together much better that VW do. It's impossible to see what you are doing to do that with the window bonded into the vehicle.
The window drain is plastic.I just drilled and through after looking at opposite sliding door mechanism which I was able to repair as I had access. Epoxy resin the pipe in place.Hope this helps
The only solution that lasts is tape on the outside. I guess a lot of vans have this problem without owners noticing it.
That is a permanent solution.Not one I saw fit for my intended use of van.All year round so ventilation important to me.Not had water down back of kitchen since draining into grey tank.3 years.
I fixed the sliding door one. I had that apart and sealed it up. Drains to the outside now, so got a decent idea of how the drains work.
But looking below my kitchen window it seems to be completely covered by bodywork, so can’t see any access to route the pipe.
I can drill through plastic drain, but have you had to drill through the metal work below so you can get the pipe to go down into the cupboard area?
No once you drill micro bore pipe hole it just runs down back as per my pictures .Then I bonded a speed fit socket into flex pipe all sound now.No issues etc.Then I sprayed lanoguard down into sills from under cabinet.
Hello - I had the leaking inside the van a couple of years ago and cleared the drain and all was well> However just had the leaking return and I used a cable tie which dissappeared inside but did not exit on the outside. I think this may have been an error! I then syringed some water into the front hole and it dissapeared! Didnt come out the normal drain hole location. I am now worried it has gone inside the panel, can anyone advise?
Only fix I can advise is a permanent on which I have done.No other way without removal of window and maybe kitchen to achieve another temporary fix .very poor vw design in my opinion along with butterfly window clips which I have also modified for a permanent engineering solution.Please follow instruction I have posted .Make sure to rust gaurd inside sills after .
