1.93m height restriction - definitely duck.Shopping centre car park:
Services | Churchill Square
www.churchillsquare.com
Prince Regent Swimming Pool (just turn up, don’t prebook, as it’s an open car park, 1st come/first served) :
Prince Regent Swimming Complex Car Park - from £3 per hour
Parking at Prince Regent Swimming Complex Car Park, Brighton, BN1 from £3.00 per hour. Guarantee your space today by pre-booking through JustPark. Monthly parking available from £650.00 per month.www.justpark.com
Or Hove seafront (meter parking) & walk.
1.93m height restriction - definitely duck.![]()
Wow thankyou for all of that! I will do some research this evening! I really appreciate your helpTry this one , multi-storey, ground floor has higher clearance than 2m stated, there is /was outside parking directly opposite also
Google photo says 2.1m clearance which seems about right.
Edit: the outside car park opposite is now Uni accommodation.
There is also a UNI carpark that can be used by the public on the weekend, the entrance is off the main run into Brighton. Tinternet search should throw up the results you need.
Edit the Uni Car park is off Lewis Rd : "Saunders Park View" - it's on the approach road to Brighton about 1m out from the Beach. If you plan the walk accordingly you will pass through the North Laines area.
Check also the Carpark at Brighton & Hove FC or the Sussex Uni carpark at the same location, the Uni carpark will be empty at weekends (with a Bus link into town. )
There is parking on the sea front to the very very far left, right by a shopping / leisure centre , I think is designated. Camper and bus parking.
Additional area immediatley next to the Marina , I.e the shopping / leisure area next to the area I mentioned above
Good luck
View attachment 131896![]()
Thankyou!Hi Marine parade on the promenade has parking available but does get busy, not sure anymore if it’s limited on time now though.
