Cali friendly parking Brighton
Kimg
Kimg
Hampshire
T6 Ocean 204
Hi guys! Just wondered if anyone knows of any decent parking for the cali in the centre of Brighton?
Thanks in advance!
Hi Marine parade on the promenade has parking available but does get busy, not sure anymore if it’s limited on time now though.
Shopping centre car park:
Prince Regent Swimming Pool (just turn up, don’t prebook, as it’s an open car park, 1st come/first served) :
Or Hove seafront (meter parking) & walk.
1.93m height restriction - definitely duck.:Nailbiting
Try this one , multi-storey, ground floor has higher clearance than 2m stated, there is /was outside parking directly opposite also
Google photo says 2.1m clearance which seems about right.
Edit: the outside car park opposite is now Uni accommodation.
There is also a UNI carpark that can be used by the public on the weekend, the entrance is off the main run into Brighton. Tinternet search should throw up the results you need.
Edit the Uni Car park is off Lewis Rd : "Saunders Park View" - it's on the approach road to Brighton about 1m out from the Beach. If you plan the walk accordingly you will pass through the North Laines area. :thumb
Check also the Carpark at Brighton & Hove FC or the Sussex Uni carpark at the same location, the Uni carpark will be empty at weekends (with a Bus link into town. )
There is parking on the sea front to the very very far left, right by a shopping / leisure centre , I think is designated. Camper and bus parking.
Additional area immediatley next to the Marina , I.e the shopping / leisure area next to the area I mentioned above
Good luck
IMG_3351.png :thumb
Orange car park is 2.13m, (the older car park which is a bit further along has the restricted height, small bays (all with a post!) and tight turns on the ramps!)
Good luck
View attachment 131896 :thumb
Wow thankyou for all of that! I will do some research this evening! I really appreciate your help
Try the CAMC Campsite near the marina!
A short walk to the bus stop where buses run frequently to Brighton from early morning too very very late:)
