Phil-B
Hi all, hoping someone can help… After doing some work on my roof it now will not operate, it’s reporting being still open although it clearly isn’t and I have error 1000.
I’ve followed all the advice I can find to clear it, but when I hold down the bottom right intro panel button it just takes me out of the diagnostics screen then when I go back in the error is still there, if I press the middle “selector” button then again it just takes me out of diagnostics with the same results.
Follow on question, I want to re-raise the roof to see if there’s an obvious issue up there, should I be able to manually do that using the release screw under the panel? I’ve been a bit scared to do that in case the roof is then stuck up!
All help appreciated
