Devaprem
Hello. For some reason, over the past four years of owning my Cali, I’ve had to replace the small length of anti-corrosion tape on just the driver’s side of the roof channel where the pop up roof section rests. On replacing it yesterday, I noticed a white line of what I think is white primer under that runs for part of the way along the front corner of the channel. Last time I replaced it, I’m pretty sure it wasn’t there (i.e. the blue top coat was still there). The front rubber edging seems soft still so I can’t think why this happened. I’m now concerned that whatever is causing it may eventually take the primer layer off, with consequent rust risk. Does anyone have any suggestions on what might be the cause and the possible remedy?
