Roof Channel Drains
Princess Doris
Princess Doris
England
T6.1 Ocean 150
Hi
We are preparing Princess Diana ( 24 plate 6.1 ) in advance of our first big trip of 2026, 12 days in Scotland including the NC500.
I put the tent roof up today and found some dampness on the front tent panel. Further investigation found a little water in the roof channels towards the front, not too much.
I looked for the channel drains and found 2 at the back, one either side, both blocked. Easily unblocked.
I can't find any at the front, yet im sure that there should be. Advice please.
Also during my search, I found 2 small rubber grommets towards the front just sitting loose in each of the channels. See photos.
Does anyone recognise what they are ?
Thanks in advance.
The front drain holes are incorporated into the Rubber grommets that the Hydraulic hoses and wiring loom goes through. The holes are underneath and slightly off center, dont be tempted to push anything down the hole as shortly after exiting the grommet the drain pipe goes into a right angled piece that can be pushed off the pipe. If blocked get a syringe with short bit of tubing and just suck the water and any blocking materials out.
