H
Hannahmary88
Hi all,
I'm new to the forum and have a few questions - I have had quite a thorough search and have perhaps identified a couple of answers for isolated things but I'm wondering if all the problems are related, so here goes:
We Brought a 2007 Cali SE130 last Autumn. These things need fixing:
- None of the 12v or the 230v electrical points work - I have checked the fuses and they all appear to be fine
- the tap doesn't work at all, no sounds of attempting to pump - I haven't investigated the tap in the fuse yet so could be that (previous owner said they never used it)
- hook up doesn't work - we plugged it in last night for the first time, tried the tester switch on the breaker unit, nothing happened, 230v socket didn't work when we turned it to on - there is a possibility the cable is faulty, bought it from a carboot seller who said it worked fine but you never know...
- our control panel doesn't work very well so it's not possible to check on here whether the hook up is connected or the state of the battery
The fridge/heater/interior lights/pop up roof all work fine
- in the fuse box the fuses for the fridge, water ump and control panel are all 30amp, in the manual it says they should be 10/5/5 - but the fridge and control panel do work so not sure if this matters
So I feel like maybe there's some central issue with on the leisure batteries or the inverter that could be causing all of these problems?
Many thanks!
Hannah
Many thanks!
Hannah
