Leaking Outdoor Shower
BeckyD
BeckyD
Luxembourg
Grand California 600
Hi everyone!
This is our first major issue with the GC. We are loving travelling in it so far.
However, the outdoor shower at the back is leaking every time we turn the water on. It leaks into the rear of the vehicle and drips every time we turn on a tap or flush the toilet. Has anyone else experienced this problem and how did you fix it?
Thanks for your help!
Becky
Hi everyone!
Becky
Hi sorry to hear of your problems.
Can you see it leaking from the rear shower specifically or is it just leaking water out at the bottom of the units at floor level, out the back?
Hello BeckyDiane1984
2 possibilities:
1 - Leak comes from temperature selector valve
2 - Shower hose connection is no longer waterproof
If necessary, disassemble the bracket to check the rear part
c'est le raccord reich qui fuit .c'est un grand classique !! on peut se dépanner avec un bouchon mâle 1/8
Thanks everyone for the replies. It turned out it was due to frost damage. We changed out the valve and it’s fine again. The same happened with the shower hose in the bathroom so that had to be changed out too. We use our van all year round so I’m now looking into how to weatherproof the weak spots
Hi, I believe we have the same issue. Did you replace the valve yourself? If so, where did you get the spare part and was it difficult? :)
This has also happened to us. Did you change the valve yourself? I drained the system in autumn but other posts indicate the valve in the rear shower is a weak spot that will fail again?
Thank you, we don’t intend to use the rear shower so have you found this to be ok long term?
The key to avoiding frost damage in this area is once you fully drain down the system plug in the shower hose and press the button to allow any residual water to be released. Alternatively press a small
Screwdriver into the ball valve which will have the same effect.
