California T6.1 AdBlue
  • Thread starter Dave- Super Keen
  • Start date
D
Dave- Super Keen
BH23 1RA
T6 Ocean 204 4Motion
Hi, Ive had my Ocean for a year now and very happy so far, only completed 6,000 miles. I've one question that I'm struggling with. Its regarding AdBlue, I put 10ltrs in at 4,000 miles but still can not find where the levels show in the menu, can you help?
Use the left/right buttons on the right hand side of your steering wheel to select Driving Data. Then use the up/down buttons and you’ll find Ablue Range.
When the level is low you’ll see a display that gives you minimum and maximum quantity of Adblue needed.
This shows the range. I am sure that I have also seen the volume needed to refill .
Maybe this only shows if the range is low ?
Just for info. Recently had an adblue issue with my 6.1 and discovered that the adblue tank is much bigger (22l) than the T6 (13l).
One of those oddities as the T6.1 appears to consume Adblue at a lower rate than the T6.
