California Ocean trailer hitch preparation 1D7
AronMartonVWCali
Satu Mare, RO
T6.1 Ocean 150
Dear members, I recently bought a Cali Ocean 6.1 with tow hook preparation 1D7. Can you help me please where is the location of the connection plugs?...or any advice how to find them... Thank you very much: Aron
The Towbar prep socket is normally taped to the inside of the body panel near the EHU/Water filler.
Access via the rear wardrobe gas/water tank or via the rear leisure battery storage area.
Thank you!
Not certain but I believe that it also needs to be programmed in so not just a plug and play job.
No problem for that, the local dealer will do it. I just want to find the socket, if i ja e to unmount something, i want to do it myself
I've been told that if you have the Factory Towbar Prep then the relevant programming has been done from the factory.
Hi everyone,
I’m trying to clarify a few things regarding towbar installation on my 2024 VW California T6.1 with factory preparation 1D7, and I would really appreciate feedback from those who have actually done this installation.
Here’s my situation:
I checked with a VW dealer using my VIN and confirmed that my vehicle is equipped with 1D7 (towbar preparation).
However, I have inspected under the passenger seat and I did not find any obvious control module or dedicated towbar wiring, which adds to my confusion.
The correct electrical kit for my vehicle should be 7LA055204A (confirmed by VW), and I also received the official installation instructions.
This is where things get confusing:
  • One installer told me that nothing inside the vehicle needs to be removed, and that the wiring is routed externally under the vehicle, using existing factory provisions.
  • Another installer claimed that the wiring must be routed from the front to the rear through the interior, requiring removal of seats, trim panels, etc.
In the official installation manual, there are indeed quite invasive steps (removing seats, accessing BCM, interior disassembly), which seem more like a full retrofit scenario, not a vehicle with factory preparation.
My questions for those with real experience:
  1. With 1D7, does the towbar wiring already reach the rear of the vehicle, or does it stop in the front area (e.g. under the seat)?
  2. Is the correct installation supposed to use an external routing under the vehicle, without dismantling the California interior?
  3. Are the invasive steps in the manual just generic instructions covering multiple configurations, or were they actually required in your case?
  4. How invasive was the installation on your vehicle in practice?
I’m trying to understand the correct procedure to avoid unnecessary disassembly on a fairly complex and sensitive vehicle like the California.
Any real-world experience would be extremely helpful.
Thanks in advance!
Francesco
Hi everyone,
Thanks in advance!
Francesco
I seem to remember that the wiring for the tow bar prep is taped to the van body near the gas bottle stowage.
Thanks, I’ve read that too — that the connector might already be present in the rear left area (sometimes taped to the body).
However, installers are telling me that with 1D7 the wiring only goes as far as the front (near the driver’s seat), and that cables still need to be routed to the rear.
This is the part I don’t understand.
Here’s an extract from the installation instruction of the kit.
As you can see, it mentions removing seats, interior trims, accessing BCM, etc. — which seems quite invasive
Does this apply to vehicles with 1D7, or is it only for full retrofit cases?
Full retrofit only.
If Towbar prep is installed from the factory then all wiring + BCM programming is installed BUT the wiring at the rear ends in a Multi Socket taped to the body panel near the water tank. So look for the connector to confirm.
Thanks, that’s very helpful.
Do you know if that connector can be accessed from inside the van — for example through the gas bottle compartment — or is it usually necessary to remove the external water/EHU panel to see it?
Also, if the connector is really there at the rear, how do installers normally access it to work on it?
I’m asking because one installer told me that in their experience most Californias (with 1D7) only have the wiring up to the front area, and that rear connectors are actually quite rare — so they usually have to run the cable all the way to the back.
That’s why I’m trying to understand what is actually correct in real-world cases.
Full retrofit only.
If the full factory Towbar is fitted then the wiring loom from the Towbar socket goes to the right and enters the vehicle via a pre-made hole on the Right forward of the combined water tank drain/gas compartment drop vent, all hidden by a plastic undertray on the Right side.
Access to the Towbar Prep connector would be via the rear wardrobe, remove bottom shelf, and look along the interior surface of the external body panel. Sometimes the tape holding the socket fails and the socket drops down between water tank and body panel.
The factory fitted wiring loom comes from the R passenger seat RHD , below the kitchen/wardrobe unit on the vehicle floor, next to the body panel, to the rear and then taped to the body panel at mid height. Then the kitchen/wardrobe module is installed in the vehicle.
From this photo, does anything look familiar to you?
IMG_5976.png I’m not sure if I’m actually looking at anything related to the towbar preparation or just existing modules/wiring.
Another detail,I checked further:
  • I found the towbar control unit under the passenger seat (5H0 907 383 C), fully connected.
  • From there, a wiring loom goes into the floor.
  • In the rear area I can only see an OEM loom (label 7LA 971 645), but no obvious loose connector.
Access is extremely limited, I can barely see anything behind the furniture.
Yes, thanks I read the post.
Today I removed the mains inlet and looked inside through the opening. I can see what looks like a capped connector fixed to the body panel (first photo). I’m also attaching a picture of the underside of the connector.
Could you please confirm if this is indeed the towbar wiring coming from the control unit I have under the passenger seat?
Thanks!
Thanks!
I'm afraid I've never seen the actual connector. You could compare the wire colours of that connector to the towbar module under the seat?
There should be some common wire colours, not necessarily all wires could be the same but some should be common.
eg: VW uses Brown for a Ground connection and the brown wire on the rear connector could go to a local earth point not to the Trailer module.
I’m not entirely sure, but looking through the mains inlet opening, that’s the only connector I can see.
On the left side (towards the water filler area) there are no additional connectors or loose wires at all.
However, I do have the towbar control unit fully installed and wired under the passenger seat, and I can clearly see the wiring loom going down into the floor.
That’s why it would seem quite strange to me if those wires didn’t terminate somewhere at the rear — this connector is the only thing I can find in that area..
Wait a moment… I think I’ve found something interesting.
I’ve just discovered this loose connector inside the mains inlet opening — I couldn’t see it before because it was wrapped in a foam cover.
Could this be the towbar preparation connector I’m looking for?
View attachment 145997View attachment 145998
Did you make anymore progress? I’m just starting out on the same path with my van.
