Calibeau
Hello fellow California owners! I’m hoping someone might be able to offer advice / thoughts on what challenges I would face upgrading the factory AGM leisure battery in our T6.1 California Beach.
My understanding is a direct swap to lithium based is not possible due to the VW battery management split charging system which is only designed for AGM batteries.
Without getting overly technical, my understanding is the battery chemistry difference between the two types is the main problem when considering the above.
I would also assume that disconnecting the factory charger could potentially throw an error as well as mess up battery charging level reporting on the camp control unit screen.
Does anyone happen to know if there are options to address / replace or upgrade from the VW split charging system to accomodate a lithium battery?
