The toilet or the bread?I also bake bread at home, but never on the toilet. Does it taste good?
Why would they do that? Could it not be a coincidence?Our current “view of our van”. After 9 days on the road and our last night via The Lakes we discovered that the narrow Fiama Pro levels and the 18” Palmerstons convert to a puncture if just using doubled up on the one wheel… gave them away to the van next to us and we’ll deal with the flat in the morning.
We have a Holts can. We’ll give that a go as soon as we loaded and ready to go. What could go wrongAtleast it’s at the end of hols, levelling chocs come in handy for getting bottle Jack/trolly Jack etc under van. Even when the AA come out
Good question. We had them doubled as the rear offside needed lifting a lot. The Fiamma Pros are quite a bit narrower than the tyre and I think I had the wheel too close to the top. The combo of a narrow leveller, tight edge and all the weight on one corner has, as far as I can see, caused the flat. We were away for a few hours and came back like that. There is no damage I can see to the tyre but trying to just re-inflate causes it to deflate again over an hour. My guess is the sheer weight and pressure has caused an issue, maybe with the sidewall seal, but it could be a nail that I can’t see just as easilly and a coincidence as you say. We drove 200 miles here so it would be a massive coincidence as everything was spot on when we parked and no warnings from the pressure monitor.Why would they do that? Could it not be a coincidence?
I'd bet on it being punctured.Good question. We had them doubled as the rear offside needed lifting a lot. The Fiamma Pros are quite a bit narrower than the tyre and I think I had the wheel too close to the top. The combo of a narrow leveller, tight edge and all the weight on one corner has, as far as I can see, caused the flat. We were away for a few hours and came back like that. There is no damage I can see to the tyre but trying to just re-inflate causes it to deflate again over an hour. My guess is the sheer weight and pressure has caused an issue, maybe with the sidewall seal, but it could be a nail that I can’t see just as easilly and a coincidence as you say. We drove 200 miles here so it would be a massive coincidence as everything was spot on when we parked and no warnings from the pressure monitor.
Recommend a visit up to the lighthouse, good little cafe there as well.
Turns out was a little more complicated. There was a sharp stone in the tyre and the pressure of the ramp on the stone right on the corner had pushed the stone into the tyre. Exasperated by the ramps being narrower than the low and wide 18s. Found it, removed sharp stone (small air leak) rotated the tyre so the leak was on bottom and used the Holts Tyreweld. Pools in the leak area to fill the gap before you then drive at 50 for 6 miles to expand the foam and increase pressure in the wheel. Worked a treat. 250 miles and home with no loss of pressure. As this actually a thread of views of van, here is one from the trip, a bland but perfunctory site on the north side of Loch Ness.I'd bet on it being punctured.
I always carry a repair kit and 12 v pump, used it many times.
https://www.amazon.co.uk/dp/B07WF2DC8F/?tag=unique09f-21
I guess that’s why they give them away with a new CaliforniaBridgestones seem prone to stone punctures as @Hedley Wright will confirm. Time to replace with another brand.
And to think I paid extra for themI guess that’s why they give them away with a new California![]()
I paid extra for the alloys., and they gave me shift y Bridgestones :/And to think I paid extra for them![]()
We were also in Ardnamurchan a week ago and had such a great spot.
Unfortunately, our planned boat trip to Staffa got cancelled because of the fairly strong wind.
(sun going down)
(This was the moon rising)
Did you also have to drive around because of one of the ferries not runn
Yes we took the long way - but it’s a lovely road especially when we stopped for a coffee brew up looking out to Eigg and Rum. its our second trip to Ardnamurchan and won’t be our last either.We were also in Ardnamurchan a week ago and had such a great spot.
(sun going down)
Did you also have to drive around because of one of the ferries not running?
The local owners had many plans for the site with community backing. It was hard standing last time we visited with a new shower block. A far cry from the old free grass field, rutted and boggy.Blimey, looks a bit more upmarket than when we stayed there in 2014. It’s a beautiful place and was/is an example of how a community site should be![]()
A lovely quiet site, below Hadrian's wall
