Jester
As you know I have been trying to have a mattress manufactured for the 680 we’ll finally found someone that has made a brilliant job, haven’t slept on it yet.
They will make it up to your specifications ie mixture of materials, hard/soft looks like a proper mattress, our mattress is made with a 7cm deep high quality latex foam, with a 3cm wool topper layer. Cotton covering, with tape edged piping to close up the mattress. You can make the mattress to various thicknesses but slightly thicker than the VW offering.
Also had ours made like OEM in three sections to enable easy access to the boot/garage. Sure they will make one in 1 or 2 piece if you ask.
As my mattress is a few mm thicker and slightly wider the Brandrup fitted sheet’s still fit. With a squeeze but works with some manipulation to the elastic staps.
I will update you on comfort over the next couple of weeks.
They now have a template for the GC 680 and keen for a 600 if your interested Contact Tim or Karen Cheetham via the website. https://www.marinebedding.co.uk/Caravan-and-Motorhome-Bedding
