thesquirrelpatrol
- Messages
- 164
So just ordered an Ecoflow delta 2 for the 600. Had considered getting the AGM batteries replaced and an inverter fitted but v expensive and questions over warranty being compromised.
Like some others I intend to fit a manual changeover switch beside the consumer unit in the cupboard, intercept the incoming wago plug to the CU from the EHU and wire from one of the 13A sockets on the delta 2 to the changeover switch taking both into the changeover switch and then refeeding the CU. In theory this should enable me to (safely) inject 230v from the delta 2 to feed the CU without back feeding the EHU inlet and, if I am correct will not only charge the leisure battery but make the internal sockets live off grid.
To charge the delta 2 I can either take it into the house off mains or plug into the 20A 12V outlet under the bed at the rear.
Anyone already done this/have any advice?
