Hi Will,Just for future reference if anyone else has this failing touch screen issue on their discover media system there is a pretty straightforward DIY fix with a replacement screen digitiser off ebay for approx £30. (Certainly easier than swapping a phone screen as a comparison to what’s involved)
I had the same issue as above approx 6 months ago but managed to replace the digitiser and it’s been perfect since. Happy to post the ‘how to‘ / part details on here if someone else has the problem down the line (PM me) but maybe all the potential failures have shown up by now.
Cheers, Will
My digitiser should arrive in one more weekNo issues, battery disconnects or coding required. It will be fine as you are just replacing the screen .
Thanks for your help, I installed the new digitiser yesterday. Looks and performs like new.My digitiser should arrive in one more week![]()
Agree with above! I have no connection to Ingleby , and wasn’t then at the stage of wanting to do the job myself. I drove to them and Ian did the entire digitiser job while I waited. An absolute gentlemanThe touch screen on our 5 year old Cali went bad last week - just where it gets the most use where the three route choices/letter 'L' on input screen appear. I contacted Ingleby Electronics on the Saturday by email through their contact page (Incidentally I have absolutely no connection with them, so this is unbiased review) Natalie & Ian very friendly, quoted £270 to replace screen plus carriage. I paid £19 return carriage online on Sunday through their ebay page and was emailed a prepaid Parcel Force Label with job number on it. I took unit out and posted on Monday. Received acknowledgement they had received on Tuesday. On Wednesday they confirmed new screen fitted and all working. I paid that day by transfer to their account and received unit back next day on the Thursday!! Works perfectly, lovely new sensitive screen, you would never know changed. So turn round was amazing 4 days from posting to them. Cannot recommend this company more highly. Total cost of repair £289, excellent value for money.
Quick tip - google 'How to remove VW Infotainment System', there are a couple of good YouTube videos. I found working from bottom right of vent trim worked well.
Kevin - Ocean, 5 years old
Perhaps be better off replacing it with a modern non VW unit, rather than nursing old tech which will most likely fail again in future.Yep, ours has gone too (2017 T6 Cali - knackered touchscreen, started approx a year ago and now barely works). Will be in touch with Ingleby directly (unless anyone knows of a SatNav specialist in the South West who can fix it??)...
see above, it’s really not that difficult to fix it yourself and save £100sYep, ours has gone too (2017 T6 Cali - knackered touchscreen, started approx a year ago and now barely works). Will be in touch with Ingleby directly (unless anyone knows of a SatNav specialist in the South West who can fix it??)...
See post #2Yep, ours has gone too (2017 T6 Cali - knackered touchscreen, started approx a year ago and now barely works). Will be in touch with Ingleby directly (unless anyone knows of a SatNav specialist in the South West who can fix it??)...
Many thanks for this. I've got a 2018 Ocean which I bought from VW last year. It developed touchscreen fault after the warranty had ended. Not wanting to have to spend a fortune on a new infotainment unit, I decided I would have to find someone who could repair it. I then saw this thread and the details of the DIY fix, so figured I'd give it a go. I spent £10 on a touchscreen from AliExpress, £10 on a set of decent trim removal tools from Amazon and £8 for some precision torx screwdrivers from Screwfix. After a few hours of very careful work (ensuring I didn't scratch, crack or otherwise damage any trim or the infotainment unit itself), I'm delighted to say that I now have a fully functioning touchscreen once again. Not sure how long the AliExpress supplied screen will last, but at least I now know how to replace it again if needed and have the tools to do so.Ok Brett, i‘ve just dug out the the photos, it was actually nearly a year ago looking at them now! Memory a bit rusty but the photos pretty much show the order of things
First the part, here’s the ebay link to the digitiser… no surprises it’s gone up in price like the rest of world. This is supplied from the EU (Germany) but you could take a punt on the cheaper Chinese delivered one (does look a different supplier though). I bought the EU delivered version.
ebay item 115045718856
If this link doesn’t work down the line then just search for “VW digitiser TDO-WVGA0633F00039”
To fit you obviously need to remove the unit, clear the kitchen table and grab your screwdrivers, fairly sure the screws were all of the small torx variety. Then pull it apart to get to just the screen…
No great surprises here, pull off the front knobs, remove any sd cards and just look for the relevant screws…
View attachment 103438View attachment 103439View attachment 103440
Once here you’ll spot a small plastic clip holding each of the two card slot gubbins (below now removed laying on their side, were vertical)
then gently ease up the 2 ribbon connectors and slide them out…
View attachment 103441View attachment 103443View attachment 103444View attachment 103445View attachment 103446View attachment 103447
Basically keep striping it down until you get to the glass unit.
Now get your new screen and after cleaning stick it over the existing one with the supplied 3m edge tape. Yes on top of the exisitng!
You will not get the original one apart as it is bonded throughout to the LCD. It is only 1mm thick and will still fit fine. In the last photo it looks like i helped the ‘fit‘ with a bit of sellotape here! Then put it all back together in reverse order but obviously connect the correct ribbon in. I left the existing one tucked out the way hence this is all completely reversible back to your original condition should you need to go back for any reason!
The end result is it looks and performs as per the original ‘working’ screen.
As said been a year now and mine’s performed perfectply.
Good luck, Will
Hi newbie here. Joined for this thread, but will stick around. Have a Caddy Maxi CNG at the moment but am an aspiring Californian. Or will convert the Caddy into a fake Cali. Time will tell. Thanks for the instructions. Just received a digitiser in the post, 19 squid from Candy Rock Mountain. One question: is there no way of removing the old one? Hairdrier? Just a matter of principle for me; feels weird to leave a broken part in place...Ok Brett, i‘ve just dug out the the photos, it was actually nearly a year ago looking at them now! Memory a bit rusty but the photos pretty much show the order of things
Good luck, Will
Honestly when you get to the point of holding just the screen you’ll realise why it’s not feasible on a DIY basis! Yes it can be done but you’d need some proper kit to massively minimise the chances of cracking the underlying LCD you want.Hi newbie here. Joined for this thread, but will stick around. Have a Caddy Maxi CNG at the moment but am an aspiring Californian. Or will convert the Caddy into a fake Cali. Time will tell. Thanks for the instructions. Just received a digitiser in the post, 19 squid from Candy Rock Mountain. One question: is there no way of removing the old one? Hairdrier? Just a matter of principle for me; feels weird to leave a broken part in place...
Thankyou willSS. Seriously helped me out. Took a little longer than expected but no damage whatsoever. Cheers for adding the the l8nk for the screen. Great price even though its now a little more. Had it delivered the following day so cannot grumble. CheersOk Brett, i‘ve just dug out the the photos, it was actually nearly a year ago looking at them now! Memory a bit rusty but the photos pretty much show the order of things
Good luck, Will
I've just had mine done, but it was free for me as I had just bought the vehicle. you tube has the repair method available and the part needed costs no more than £15. It takes around an hour to fix and TBH looks like an easy DIY task.We’ve had problems with the the touch screen for a couple of years on a 5 year old California,the L hasn’t worked for a long time on the satnav..You can’t programme satnav on touch screen only on voice control.If you try and touch the satnav screen when it’s running it will no longer move with the route and even jumps to countries all over Europe,you can’t re centralise the screen.The radio programmes jump all over the place too,keeps changing stations .Took it into the van centre they diagnosed that the control unit behind the touchscreen needs replacing at a cost of £2200.I’m not even convinced that it will fix it because the letter L isn’t working.A customer who overheard said to me it sounds rubbish seek a second opinion.Any ideas I don’t want to spend all that to have the satnav still not 100%
I doubt they will replace just the screen but the whole unit. Worth a try.I also have the dodgy screen, anyone had this replaced under the all in warrantee?
