Thank you for that Alec - I hadn’t seen any mention of that before so really helpful.There are two feeds into the drain one from the window track and a smaller one that is located up against the glass and is not obvious.
@AlistairC you have done what I have always thought must be the only successful method of fixing this problem. Why on earth VW didn't issue an instruction to dealers to do just what you have done when changing windows under warranty way back in 2003/4 when the problem first arose I will never know. Then fix subsequent production as vehicles were manufactured.
My fear is that now I have a MN TGE due any day with sliding windows both sides in the rear I will still have the same problem! Time will tell no doubt.
If I recall the slot is so thin a cable tie didn’t fit. I’m actually wondering if the slot is actually a breather for the drain given its size and position.Thank you for that Alec - I hadn’t seen any mention of that before so really helpful.
I’m going to have a look at my old window now to see if that was one of the design revisions they made along the way. I presume the channel you have identified actually is a straight though and therefore OK to use to poke clear with a cable tie ?
@BristolCali no need to apologise, you are not being patronising at all. Your query is the same as every dealer and quite valid.Apologies in advance for patronising, focussing in on it ‘having play’ when it’s closed and the van being new, are you sure it’s closed properly? In my experience everyone else that uses our cali doesn’t push the window in when closing, it’s not an intuitive action. You need to simultaneously pinch the catches and keep pushing out until it seats properly and should be flush when you look from the outside.
That is really something! My 2005 Cali SE had the same. Drain holes out of order. Fixed it with new rubber seal. But that would be last resort for you. I hear warranty repair.Best test is to use a syringe and direct water down the drain hole.
I would focus on the faulty drain rather than the window rubber/seal. Hard to believe that VW have not sorted this yet! My 2013 T5.1 had the side window replaced 6 years ago and the flaw in the drain was obvious well before that.
Can you more specifically describe the location of that in the pic.?To add to what Rod has already said above (he is very correct on all this - thank you Rod for your thread on other forums!), yes, the lower drain channels are very poorly adhered onto the sliding window channels.
I’m about to bond on a brand new VW window unit so I’ve given it some good investigations! The bottom part appears to be fixed with a bonded neoprene gasket which whilst stretchy, really is very weak. As said above, I really wouldn’t advis poking anything down there for fear of breaking that seal.
I have gone belt’n’braces on this problem and encased the entire drain system in Bonding sealant Before adhering it to the van. Fingers crossed eh!View attachment 100809
As a follow up, I cleaned the window and channels thoroughly (even though it was only a few weeks old at the time) and it seemed to help.Hi, our 3 week old 6.1 Ocean is suffering the leaking side window issue.
I’ve read a number of the previous threads, I just wondered if there was any updated info for the T6.1 sliding windows. None of the drain holes seem to exit under the window glass…if poke with a small cable tie but it’s hitting something and doesn’t go all the way through.
Also, the window when fully closed, still has some play. If I push from the inside I can see water being squeezed out and dripping behind the cooker/sink. Is there any adjustment possible on the window to pull it in closer to the rubber seals….?
I fear you’re right, judging by the number of times windows have been replaced with little or no improvement.I've had three T5s and a T6 since 2007 all with sliding windows that leak. I took one back to the dealer who replaced the complete window.
It's fair to say that if VW haven't managed to fix this problem in almost twenty years of production you are all wasting your time taking a vehicle back to get this problem fixed under warranty. It's a design fault that they have never admitted exists. A dealer will, if pressed, change the complete window but the new one will still inherit the same problem.
If a new window doesn't leak immediately after change if you use the opening feature it will leak in the not to distant future.
Where did you drain to? I suppose tapping into the sink’s waste would work well?Worked a treat for me.
That is correct .sills will eventually rot and need replacing .People don't realise thus until it is to late.
