couplands
Hi, our 3 week old 6.1 Ocean is suffering the leaking side window issue.
I’ve read a number of the previous threads, I just wondered if there was any updated info for the T6.1 sliding windows. None of the drain holes seem to exit under the window glass…if poke with a small cable tie but it’s hitting something and doesn’t go all the way through.
Also, the window when fully closed, still has some play. If I push from the inside I can see water being squeezed out and dripping behind the cooker/sink. Is there any adjustment possible on the window to pull it in closer to the rubber seals….?
