KGCali
Retired and still young at heart!
Thanks but all sorted now, got the front struts and springs from a two year old T6 with approx 20k for £50 then got new top mounts, bearings and drop links. Purchased new rear springs from VW and got new Bilstein rear dampers and rubbers, great ride now. Old rear dampers were dead. I also changed the front and rear anti-roll bar bushes. Drives like new now!Hi, did you get sorted? I have just changed mine, have the correct front markings but no markings on the rears
ooh! that would have transformed the van ride and handling. IMHO bushes are a must to change after about 5 to 6 years, max 10. I am looking at upgrading to polybushes. more adjustment and longer lasting.Thanks but all sorted now, got the front struts and springs from a two year old T6 with approx 20k for £50 then got new top mounts, bearings and drop links. Purchased new rear springs from VW and got new Bilstein rear dampers and rubbers, great ride now. Old rear dampers were dead. I also changed the front and rear anti-roll bar bushes. Drives like new now!
Here's a parts list for my suspension ...
SUSPENSION T5.1 4Motion 2010
FRONT SUSPENSION LEG
7H0413031N now superceded by 7E5413031C or 7E5413031H from 2018 checked with VW.
Front Shock Absorbers, Pair, Gas Filled, T26, T28, T30
Gas filled front shock absorbers pair for T26, T28, T30 models.www.heritagepartscentre.com
FRONT SPRING
7E0411105D x2 - PR Code 0JF (zeroJF) Weight category front axle weight range 6
2 paint marks Grey 1 paint mark Green
Front Suspension Coil Spring 2x Grey 1x Green Marks
Front suspension coil springColour coding x2 grey x1 paint x1 green paint marksT5 03- T6-19www.heritagepartscentre.com
REAR DAMPER
7H0513029D x2. Now 7LA513099 checked with VW
NOTE: I fitted BILSTEIN B6 SINGLE REAR DAMPER UNIT - VW T5 T6 03 from![]()
Rear Shock Absorbers, Pair, Gas Filled, T26, T28, T30
Pair of top quality Meyle Gas filled rear shock absorbers for T26, T28, T30 modelswww.heritagepartscentre.com
Bilstein B6 Single Rear Damper Unit - VW T5 T6 03-24 - Vanstyle
www.vanstyle.co.uk
REAR SPRING
7H5511115M x2 - PR Code 0YJ (zeroYJ) Weight range 9 installation control only no requirement forecast
1 paint mark White
Rear Suspension Coil Spring Paint Marks x1 White
Rear suspension coil spring, T5 03-T6 16-19www.heritagepartscentre.com
ANTI-ROLL BAR BUSHES
Front
7H5411313A Rubber bush 23mm
Rear
7H5511414 Rubber bush x2 23mm
7H5511413B Rubber bush x2 23mm
Hope that helps others
View attachment 99881View attachment 99882
______________________________
