Wanted 4Motion Suspension and Springs Wanted
KGCali
KGCali
Retired and still young at heart!
Essex
T5 SE 180
Hi All
As anyone got a set of original low mileage suspension from a 4Motion after they've uprated the suspension?
I'm after the front springs marked with two grey and one green stripes and the rear springs marked with a single white stripe. Happy to take the struts as well if in a kit.
Hi, did you get sorted? I have just changed mine, have the correct front markings but no markings on the rears
Thanks but all sorted now, got the front struts and springs from a two year old T6 with approx 20k for £50 then got new top mounts, bearings and drop links. Purchased new rear springs from VW and got new Bilstein rear dampers and rubbers, great ride now. Old rear dampers were dead. I also changed the front and rear anti-roll bar bushes. Drives like new now!
Here's a parts list for my suspension ...
SUSPENSION T5.1 4Motion 2010
FRONT SUSPENSION LEG
7H0413031N now superceded by 7E5413031C or 7E5413031H from 2018 checked with VW.
FRONT SPRING
7E0411105D x2 - PR Code 0JF (zeroJF) Weight category front axle weight range 6
2 paint marks Grey 1 paint mark Green
REAR DAMPER
7H0513029D x2. Now 7LA513099 checked with VW
NOTE: I fitted BILSTEIN B6 SINGLE REAR DAMPER UNIT - VW T5 T6 03 from
REAR SPRING
7H5511115M x2 - PR Code 0YJ (zeroYJ) Weight range 9 installation control only no requirement forecast
1 paint mark White
ANTI-ROLL BAR BUSHES
Front
7H5411313A Rubber bush 23mm
Rear
7H5511414 Rubber bush x2 23mm
7H5511413B Rubber bush x2 23mm
Hope that helps others :)
______________________________
FRONT SPRING
REAR DAMPER
REAR SPRING
1 paint mark White
Front
Rear
View attachment 99881View attachment 99882
ooh! that would have transformed the van ride and handling. IMHO bushes are a must to change after about 5 to 6 years, max 10. I am looking at upgrading to polybushes. more adjustment and longer lasting.
matt-k918
briwy
KGCali
KGCali
N
NessieBeach
N
Chris Edwards
T
T6 RXC
T
