Hook up in France
K
KBR
Somerset
T5 SE 180
Hi all,
Off to France soon and heading to a site with 12v hook up. Wife has a hair dryer which has a travel mode which is rated at 125v and 1200w. Can we use this when on hook up?
I imagine it’s a big no if we aren’t on hookup?
Thanks.
Yes. No problems. Just use the three pin plug next to the sink of your van has one.
You can use it in the three pin plug in the drivers seat too when not on hook up. I do believe that the battery monitor will dance the Macarena if you do.
As far as I know the mains voltage in France is 220-240v so an appliance rated at 125v will struggle.
It can also be used at 230v/1850w or 240v/2000w. Should I leave it on that setting? I didn’t want to trip anything!
3 pin next to drivers seat? Didn’t know there was one! Don’t think there is on my T5. I’ll avoid using it when not on hookup. I don’t think the 3 pin by the sink works when not hooked up anyhow.
The inverter socket is now on the UK drivers side seat, on the T5 it's on the UK passenger side B pillar.
A 240v 2000w device will draw a little over 4 amps. In most cases I have come across hook-ups deliver between 6 and 15 amps, very often around 10. So you should be ok, but if in doubt check with the site.
The 3 pin by the drivers seat thats being referred to on later vans is a 300w inverter, T5 had the 150w inverter on the B pillar behind the passenger seat.
Neither would be any good to you if the dryer is 1850w
But the sink end 3 pin socket will be fine when on hookup.
From my O level physics... Amps = Watts/Volts which in this case there will be a draw of just over 8 amps so tread carefully!
Hi all,
Thanks.
12v hookup seems unlikely, probably 220v like in whole of Europe. Isn't the travel mode meant to be used in countries like the USA? Probably not a good idea to put it on 125v and plug it in a 220v outlet :p
