Roof problem
P
peterbrown
2011 180 DSG
Hi, having had no problems at all with my roof, yesterday it failed to close after being up for the day at Brands Hatch. Eventually had to do a manual close ( first time ) .
Once home had a go and it did respond to close roof and lock it down . Tried the open roof process and it goes up but kept stopping so had to release and repress button, however it doesn’t go fully up ( around 95 per cent ) and doesn’t make the usual noise that get at the end of open and close. Now won’t close again.
Hope this makes sense !!
Any assistance will be greatly appreciated
Peter Brown
Hello Peter,
I'm sorry, I can't help with your roof problem I'm afraid. Just wanted to say what a great day it was at Brands Hatch yesterday. Brilliant entertainment.
£14 for a portion of luke warm fish a chips was a bit of a shock though!
2011 180 DSG
Peter Brown
Forgot to mention that I have the elevating roof symbol flashing on the control display.
Pb
Hello Peter,
Thanks Borris , yes a great day out until roof issue
Pb
Pb
seems i am having the same problemroof stops when opening and closing
then it mentions 'start engine' on the screen
when engine is running the alarm starts after a few secondswhen i shut the engine down, i can open / close the roof a bit more
it took 2 times of starting the engine untlll it was fully open/ close
what was the matter with yours ? ( here easter holiday , so garage closed )
Normally you get that if the Leisure Batteries are low in power/voltage.
2011 180 DSG
Peter Brown
For those of you who don't know, if you ever get any problems with roof stuck or any other error say with the heater or fridge, you are able to access the hidden menu in your control panel as used by the VW Engineers.
Access as follows:
1. Hold down the centre of the rotary button together with the menu button (button below with the squares on it)
2. You will get the hidden menu.
3. Rotate the rotary button to get to "VW diagnose" and select this by pressing on the centre of the rotary button.
4. If no errors are present it will display "no errors"
5. If Errors are present then a list of errors will appear
6. Press the centre of the rotary button again to delete all the errors
7. Repeat process above just to check that errors have dissapeared!
8. Re-configure the time and date if neccesary.
Any problems should be resolved assuming these are Electronic and not Mechanical.
Error Codes from Control Panel.
1 = 1 = Pop-up roof
2 = 2 = Plumbing Heating
3 = 3 = Cool box Cooler
4 = 4 = Sewage wastewater
5 = 5 = Fresh water
6 = 6 = Outside temperature
7 = 7 = Battery
Error Code Defect Fault
1010 1010 Short-circuit to (earth) roof
1001 1001 Fuse / short circuit to (plus+) roof
1100 1100 Short-circuit output Roof "on"
1101 1101 Fuse roof "to"
1110 1110 Short-circuit output Roof "to"
1111 1111 Fuse starting Roof "to"
2100 2100 Short-circuit output heating on / off
2101 2101 Fuse output heating on / off
2001 2001 Interrupt input heating 30
3100 3100 Short-circuit output coolbox
3101 3101 Fuse interrupt output coolbox
3001 3001-J698-cooler input error "Active"
3010 3010 Short-circuit input icebox "actual temperature"
3011 3011 Interrupt or fuse input icebox "actual temperature"
4000 4000 Short-circuit to ground water level sensor
4001 4001 Fuse circuit to plus water level sensor failure
5000 5000 Short-circuit to ground water level sensor
5001 5001 Short circuit to plus water level sensor failure
6000 6000 Short-circuit to ground temperature sensor or for outdoor temperature
6001 6001 Fuse / short circuit to plus two temperature sensors for outside temperature
7001 7001 interrupt input interrupt input D +
Access as follows:
1 = 1 = Pop-up roof
5 = 5 = Fresh water
7 = 7 = Battery
Thank you for that Welshgas, saved that onto my laptop.
Access as follows:
1 = 1 = Pop-up roof
5 = 5 = Fresh water
7 = 7 = Battery
You see replies with attached posts and help like this is invaluable, thank you Kevthegas
