OllieCollieCali
Hi All,
I recently purchased my 2006 California, and was told it has the 2 aux diesel heaters, although the control unit says " Auxiliary Heater Not Connected" when you press the heater control.
After some investigation, I definitely have both heaters under the van, the coolant heater is working fine, and the parking heater exhaust all looks brand new so probably never been used.
Without taking the panels off to reveal the heater under the van, I have seen the wires from the unit come through a rubber grommet in the floor under the drivers seat. I have 3 x connectors under the seat that don't seem to go anywhere, and I believe the 2 larger connectors in the picture below are to do with the heater unit. They come up through the rubber grommet in the floor, and have a wire going to a grounding bolt. The smaller connection comes from another wiring loom, but no idea what it does.
Tonight I took out the control unit by the rear view mirror, to see if it was missing a connector but it has all 3 connectors plugged in, and assume one of these is the heater?
So my question is... Does anyone know where the wiring from the parking heater goes? Which of the connectors on the back of the control unit is for the heater? Hopefully I can trace that wire back a bit if I know if its the heater. Its unlikely the heater was fitted without the wiring, but not sure where to look to find the wires and hopefully connect it back up. Does everyone else have these 2 larger connectors under the seat for heaters?
Pretty sure its the webasto Airtop 3500 heater.
Thanks in advance!!
Thanks in advance!!
