GaryLynn
Looking for some advice here.
Had a bad experience recharging an electric toothbrush using the inverter socket - two plug in chargers failed to work when used this way and subsequently failed to work when plugged in to a house socket. Browsed these forums and found others have had similar problems. I’m no electrical expert but this seemed to attributed to the ‘quality’ of the AC voltage - apparently not a true sine curve or anywhere near it. Seems the inductive charging technology used for toothbrushes is sensitive to such things.
I’m now contemplating charging a rechargeable electric shaver using its supplied cable plugged into the adaptor plugged into the inverter socket. I’m a little apprehensive given my experience with the toothbrush but appreciate the shaver does not use inductive charging.
What experience to folks on here have of recharging electric shavers this way?
Cheers!
Cheers!
