You might be able to keep the bed, the problem will be, most High Tops I’ve seen don’t go as high as the pop top roof so the bed won’t go as high.I‘m starting to relax about the fibreglas. The key is can I keep the bed completely as it is now. Including raising it when not in use. I suspect not. Best idea so far though.
I am 6ft and the ceiling in our high top is at least 9" above my head when standing up inside.You might be able to keep the bed, the problem will be, most High Tops I’ve seen don’t go as high as the pop top roof so the bed won’t go as high.
You should ask that question.
And? I’m also 6’. and there is more than 9” above my head when the Pop top is up. My point is in the California with the pop top up the upper bed can be pushed upto the same angle. With a Hard top roof and retaining the California hinged bed, I’m not so sure if the bed could be lifted to the same angle.I am 6ft and the ceiling in our high top is at least 9" above my head when standing up inside.
Just pointing out that there is plenty of room, nothing else. That space goes all the way to the back, unlike a pop top. We do not have, because we did not want one, an upper bed. There is no design reason why a hinged bed could not be included in a high top but one would lose much of the available space at the back. One solution would be to have a upper bed that conserteens (sic) at the rear. I have a feeling this option does exist but can't recall where I saw it.And? I’m also 6’. and there is more than 9” above my head when the Pop top is up. My point is in the California with the pop top up the upper bed can be pushed upto the same angle. With a Hard top roof and retaining the California hinged bed, I’m not so sure if the bed could be lifted to the same angle.
Most High Tops I’ve seen have a different bed system compared to the California.
The majority of roof beds, in a high top slide from front to rear or vice versa. That is the sensible method. Using a hinged bed, ala California, as the OP mentioned would negate much of the head room advantage .Just pointing out that there is plenty of room, nothing else. That space goes all the way to the back, unlike a pop top. We do not have, because we did not want one, an upper bed. There is no design reason why a hinged bed could not be included in a high top but one would lose much of the available space at the back. One solution would be to have a upper bed that conserteens (sic) at the rear. I have a feeling this option does exist but can't recall where I saw it.
I agree.The majority of roof beds, in a high top slide from front to rear or vice versa. That is the sensible method. Using a hinged bed, ala California, as the OP mentioned would negate much of the head room advantage .
No criticism intended, except that a hinged bed + high top isn’t really a good combination.
I am only really likely to pursue the idea if I can’t fix my roof sensors.You might be able to keep the bed, the problem will be, most High Tops I’ve seen don’t go as high as the pop top roof so the bed won’t go as high.
Love the wingamm bed very clever, only down side is the head room when shut isn’t great if you’ve over 6ft.Agree - A simple single hinge point bed as per a Cali in a high top roof does not work as you lose your standing height rapidly.
However, if you incorporate a second hinge point designed to match the curve of a high line roof (and if your front hinge incorporates a sliding action), then you end up with a drop down bed that will closely follow the roof profile, giving you maximum height in the living area within a short van (see pic)
The sliding roof bed options generally used in high tops work well (for example in the Joker) and many with high tops simply sleep downstairs but want the extra height of a high top for permanent standing room, better insulation and increased storage capacity.
Did like this https://www.newwavecustomconversions.co.uk/client-builds/newwave-rent-high-top-verso-conversion/Love the wingamm bed very clever, only down size is the head room when shut isn’t great if you’ve over 6ft.
Amazing layout though, shame they don’t make VW ones anymore.
I was just about to post that.
If it doesn’t have a loo or shower then no benefit to me, would have a cali again.
Yes, this happened to ours after a while, it did take 9 years though.I’m just not a big fan of fibreglass. A friend has a great T4 Westphalia and it’s roof peels after a while.
HelloIf you take your California to Autohaus in Minehead they will put a high top on, like picture - this is not a California. I think they will be surprised at the request, but they will do it. Price, at a guess £5k.
Can I ask where you had it done and how much?Hello
That’s exactly what we did September 2020! Covid delayed things somewhat but finally got the job done August this year and we couldn’t be more pleased!
Our reason to change the roof was medical, both of us having back problems and after having to cut a couple of holidays short we thought our camping days were numbered. It’s was a struggle when the roof was down which was our problem, it’s not always convenient to pop the roof.
It did come with some ‘extras’ though. Not only storage but the roof corrosion problem had returned worse than when it was done the first time.
HiCan I ask where you had it done and how much?
Thank you. Do you have any internal pictures?Hi
We had it done at Autohaus Minehead.
It was around the £5k mark but included in that was the side bars and decals. They did say it was much trickier than expected as it was their first California.
Thank you. It really transforms the internal space with lots of extra storage and of course full standing height all the time.
wow thats pretty drastic - but if it suits then it got to be
I suppose it is drastic! It wasn’t a decision taken lightly but hopefully will give us another five or so years of camping!wow thats pretty drastic - but if it suits then it got to be worth it
