Loose stove burner
Maria Taplin
UK
T7 California Coast
Hello folks - has anyone else had a loose stove burner. Is it possible to tighten and how do I do it? Thank you
Hi - thank you
The two screws at the top have rusted - I thought hey just held the plate but see now that they hold the burner in place
As you can see in the pic, the screws are badly rusted and stuck in.
Bit of a mess - need to get the rusty screws out somehow and replace.
The igniter is wobbly too.
But the burner does work at least ☺️
Cheers
Hi - thank you
Cheers
Tricky! I fear that you will need to very carefully drill out the old screws. Try and ‘centre punch’ the rusted screws to avoid the drill dancing around. Good luck Maria.
Hi - thank you
Cheers
Soak the screws in a releasing agent, WD40 or Plusgas a few times and use the correct sized screwdriver or pliers to loosen them.
From the photo, it looks like the screws have rusted and the head has sheared off.
laurentfox
7K
jts46
jts46
gingerrob
Padraic
Padraic
P
6K
ja197
Chinmusic
Chinmusic
