Never had a problem with my pipe falling out !!Simple method to hold the water filling pipe in the filler neck of your van. Stops it falling out even when using high pressure:
For a moment I thought it was to do with something else...For a moment I thought this thread was something to do with ...
My pipe keeps falling out! I’ve got a length of blue food grade hose which I try to avoid contact with the van and the ground while filling but the tap is diagonally opposite the van so it’s a right palava and inevitably get soaked in the process. Where do you get those from?Simple method to hold the water filling pipe in the filler neck of your van. Stops it falling out even when using high pressure:
This funnel is usually attached to a water filling pipe tofu dish in camping shops. Or look here on Amazon: www.amazon.co.uk/dp/B00WMCNYCK/ref=cm_sw_r_sms_api_glt_fabc_V7DZE38XP2BMZY3FJ99V?_encoding=UTF8&psc=1Sorry, the question has already been asked.
After all these years I still have not found a better solution that stops the pipe falling out during filling.Simple method to hold the water filling pipe in the filler neck of your van. Stops it falling out even when using high pressure:
