solutionz
I'm looking for a comprehensive list of options / PR codes that may be currently available to order ex factory and/or ex dealer for the T6.1 Ocean.
Going through the latest brochures for the different countries (UK, Ireland, France, Germany, Australia, NZ) there are a number of codes only listed in one or two of them, or without codes, partial descriptions etc so requires cross-referencing between them.
For example 2021 VW Ireland T6.1 brochure lists:
[YEL] Equipment Package “Protection”
[YER] Underbody Cladding for Engine and Transmission, smooth aluminium
But then only the 2021 French brochure has the full descriptions (via Google translate) and lists them as options specifically for the T6.1 Ocean:
[YEL] "Protection" equipment package base plate protection for engine, gearbox, tank, rocker panel, differential, silencer. main
[YER] Underbody protection plate for engine and gearbox made of smooth aluminum sheet
This appears to be the Seikel kit however unclear if it's ex factory or dealer fit option.
This forum is the only place I see two mentions ({1}, {2}) from 2016 of [YEQ] Seikel Desert Suspension; again is/was this a factory or dealer option?
The 2020 French brochure lists two other suspension options; [1BJ] and [1BB] Uprated suspension/shock absorption in front and rear +20mm -are these similar to the above?
I've also seen claims that VB Air Suspension is/was a factory option? It at least seems to be a dealer option in some places however I haven't come across any codes for it.
I'm also looking for any docs specifically showing [IS2] Terminal strip (IS1) and multifunction control unit (IS6) or either of them (IS1 required for VB Air) specifically available for the T6.1 Ocean model as in addition to the base Transporter currently I've only been able to find it listed for;
UK T6 Cali Ocean
AU T6.1 Cali Beach (lists description without code)
DE T6.1 Multivan, Kombi, Grand Cali etc
It would be nice to know the difference between these:
[1S1] Tool kit and jack
[1S6] Heavy-duty tool kit and jack
And to have an updated listed of glass / tint options as the latest version I can find is on this forum for the T6 and is missing detail on [Z2C].
And of course to correct what is obviously the biggest spec'ing oversight for a camper it's be great to find a way to get these parts retrofit in NZ;
[199 398 500 A] and [199 398 500 B].
UK T6 Cali Ocean
